lol blanked the oe one off fitted the same as the how 2 z20net not got code reader till wednesday
All I can say is we told you not to mate lol possibly the car not seein the pressure or gettin proper reading you got limp mode
lol must be somat simple
Yes take the Chav valve off mate you don't need that silly noise am only 22 and I Laff when I here it makes me giggle just put it back as it was
lmfao
wen i bought my car,with valve fitted, it had the eml light on perminantly.
despite being put on diagnostic kit they couldnt id the source. I decided to sprey carb cleaner up the air intake(yes i knew it was injection) past the maf and the code disappeared and hasnt come back in nearly 4 yrs.
the EML is on correctly though bud , how can you find a fault when there isn't one as such !? its a pressure thing , the car probably thinks there is a turbo or boost problem due to the DV venting to atmos
What dv have you used and where have you taken the vac pipe from there is a little censor at front of engine under plastic cover disconnect start engine then turn off snd reconnect and start car again should take it of did that to mine and worked
It's not a chav thing it's personal taste and the defo of a chav is chav (pronounced /ˈtʃæv/ chav) is a stereotype of certain people in the United Kingdom. Also known as a charver in Yorkshire and North East England[1] "chavs" are said to be aggressive teenagers, of working class background, who repeatedly engage in anti-social behaviour such as street drinking, drug abuse and rowdiness, or other forms of juvenile delinquency.[2
