Results 1 to 10 of 14
Thread: LED number plate light fault
    Regular Member SRIDAN's Avatar
    Out in the Estate
    5 Post(s)
    Vehicle : Sri Estate Navi xp2
    Trim : Leather
    Engine : 1.9 + a little extra
    Mileage : 80,000
    Default LED number plate light fault
    fitted my new LED'S tonight and they look really good,only prob is when i turn the number plate lights off,the led,s flash for 11 seconds then stop.Any idea?
    Theses are the ones i got
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
    scottish region
    Yes strobing you get it with all leds on vectra I'm affraid I ended up taking all ming out
    Out in the Estate
    5 Post(s)
    Trim : Leather
    Mileage : 80,000
    Ok thanks,Didnt say that on ebay!
    11 Post(s)
    Quote Originally Posted by SRIDAN View Post
    Why should they?
    Surely you can't expect them to list every single car they are or aren't compatible with?
    On a Sabbatical mickeystitch's Avatar
    Mar 2007
    peacehaven
    Why should they?
    Have you checked his link they clearly state they are suitable and will not cause errors on vectra c so get his point completely
    Engine : 1.9 CDTi
    They dont cause errors as in they dont put on the bulb warning light.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by mickeystitch View Post
    Technically that is correct, they're not putting on the bulb warning light like most other LEDs do so not causing an error. The pulse isn't an error, it's just one of those things.
    11 Post(s)
    OK, hands up, I didn't.
    Quote Originally Posted by cont1204 View Post
    It's actually the bulb check system causing the problem, although I don't know why it does it with the number plate lights as they're not part of the bulb failure warning circuit.
    Engine : 1.9 CDTi
    Because its canbus (Nothing to do with bulb check)
    Its checking to see if that bulb has continuity and if it doesn't (Bulb blown) it turns that circuit off.
    It sends a short burst of power to the circuit that doesnt illuminate the bulb as its too quick to see. The leds are a lot quicker to react and thats why you see them pulse.
    scottish region
    All the bulbs do it for some reason my interior bulbs done it aswell which was strange lol
  1. Number plate light
    By ronaldodg9 in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2012, 05:18
  2. Number plate light problem.
    By carperjake in forum Electrical & ICE (including SatNav)
    Last Post: 28th July 2012, 17:28
  3. Tail light/number plate light wiring...
    By kyuudousha in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 12:34
  4. Signum number plate light
    Last Post: 3rd November 2010, 22:32
  5. Number Plate Light
    By kiwigolfer in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2009, 23:10
