Thread: 2.2se Lambda sensor help
    Regular Member SRIDAN's Avatar
    Out in the Estate
    8 Post(s)
    Vehicle : Sri Estate Navi xp2
    Trim : Leather
    Engine : Z19dth + a Teapot
    Mileage : 94000
    Default 2.2se Lambda sensor help
    Hi
    Just about to fit a cat back exhaust from a 04 2.2 direct on to a 2.2 non direct, just has a quick under the car and the Lambda sensor is on top of the exhaust man, but on the new pipe itís on the centre section, Do they have two one before and after the cat? If not then I will just blank it off.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    I think both have 2 mate, one before and one after. I put a 2.0T system on my 2.2 SE. All I did was cut it just before the Y and boot side of fuel tank and clamped the larger pipe over my stock SE pipe.
    Out in the Estate
    8 Post(s)
    Trim : Leather
    Mileage : 94000
    Ok but on my se the middle section is about 3ft long and on the new one its 1ft long so wanted to change it all.have to book up pipecraft asap.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    LOL yea know what you mean, its because the direct has 2 rear boxes to do the work. the 2.0T has no centre box, its straight through. I've kept my 3 foot middle box and now have the 2 rear boxes, from the rear the car is silent.
    I've still got an Irmscher Y section and Irmy Quads to bolt on in the cellar. Things dont happen very fast in our house, its not a case of Rush by name.......
    Out in the Estate
    8 Post(s)
    Trim : Leather
    Mileage : 94000
    Lol,you don’t think it will be too noisy do you with the direct mid section? If so I will keep my original box.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    No mate, it will be the same as a Direct, as said the only reason the direct has a smaller middle box is because it has two rear boxes to silence the same flow of gas. So double the silencing.
  1. where to buy Lambda Sensor
    By signum04 in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2012, 08:56
  2. Lambda sensor
    By danno91 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th August 2011, 16:06
  3. Lambda sensor
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2010, 13:08
  4. lambda sensor
    By deg in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2009, 18:35
  5. Lambda sensor - Z32SE - where is bank 1, sensor 1?
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2008, 14:46
vectra c. blank lamba censor 2
