Thread: Oil leak from oil return pipe after fitting turbo
    May 2011
    lancs
    Default Oil leak from oil return pipe after fitting turbo
    As above, fitted new turbo and intercooler started her up and wey hey car was idling for around 20mins no probs then seen small oil drips coming from oil return pipe(engine side) it had a new gasket fitted and torqued to specific torque, Is it leaking as it's a new gasket and needs to bed in proper when heated??
    Thanks In Advance Tommy
    WGAF#5
    nope - they dont bed in they should be tight and free of leaks on fitting
    are you sure you didnt catch it on fitting ?
    May 2011
    lancs
    no i've read a few posts where peop0le have bent them so i fitted it after i fitted the turbo to be safe, It maybe just needs bending a little more cos they are a ****** pain..
    WGAF#5
    indeed they are buddy... having done a turbo replacement i know your pain
    May 2011
    lancs
    Cheers deztroyer, am i right in thinking that the gasket is pretty thick and not the thin metal ones with the 4 little straps that you fold over?? if so then vx sent me the wrong one
    WGAF#5
    well the ones on the 2.0T z20net petrol engine were the thin metal types ... which were directional
    ... so i think you need to ask someone like Neutron who's had the turbo's in and out of this Dirty Diesel more times that i've had hot dinners
    May 2011
    lancs
    lol ye good thinking just pm'd him. i'm sure i read somewhere they upgraded the gasket but can't find it anywhere. i know the gasket they sent for the turbo side of the oil return pipe is a different on than the original, The original was one of trhe thin metal ones but the new one is a thicker one. Cheers Tommy
    May 2011
    lancs
    all sorted now car up and running had alot of smoke on initial startup, but it has been stood for a month after turbo failure and the smoke seems to be dying down and fingers crossed all will be good. Big thanks to any member that shared their info since i bought the car. BIG Thumbs up to you all. Thanks Again Tommy
    WGAF#5
    yep there will be some excess oil in the pipes and potentially the exhaust system that need burning off...
    good stuff mate .. glad its sorted
  1. leak off pipe
    By jones5n in forum Engine & Drivetrain
    Last Post: 3rd December 2011, 18:50
  2. estate fuel return pipe
    By DaveG in forum Engine & Drivetrain
    Last Post: 25th October 2010, 16:49
  3. Fitting a clutch return spring
    By Reading1800 in forum Engine & Drivetrain
    Last Post: 10th June 2010, 18:01
  4. Oil leak from the pipe....
    By PAULMAC77 in forum Engine & Drivetrain
    Last Post: 17th April 2010, 11:56
  5. Leak off pipe
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2010, 20:28
turbo fitting oil leak
oil in pipe after turbo
143760fr.montizer
