Results 1 to 3 of 3
Thread: Vectra C Sticking Gear Shift
    Jul 2011
    Loughborough
    Default Vectra C Sticking Gear Shift
    Separated by a month and 1,500 miles I have experienced problems with my manual gear shift. On trying to change down, I found that after disangageing, the shift lever can't then be put into ANY gear at all and I had to just roll to a stop in neutral. After stopping, switching off the engine and then re-starting the problem was cleared both times, and the gear shift returned to normal. Concerned that this might happen in fast lane on a motorway so any ideas as to the cause will be most appreciated. After first incident my local garage had a look but could find nothing wrong as it was by then working OK. Car is a 1.8 Sxi five door, registerd December 2003.
    Thank you in anticipation of some suggestions as to the cause.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    clutch or gear box may just be the selctor worn out
    Jul 2011
    Loughborough
    Clutch was changed only last year and gearbox seems to work perfectly OK. Is there any way to check and confirm that the gear selector is worn ? If it is the selector, then why would the problem be completely cleared by just stopping and re-starting the engine ?
  1. Sticking To My Vectra.
    By Mark The Cabby in forum General Motoring Chat
    Last Post: 16th February 2013, 17:50
  2. Gear Shift Knob Removal
    By ian 1234 in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2013, 10:24
  3. fitting a shift light to a vectra c 2002
    By vecsey in forum Electrical & ICE (including SatNav)
    Last Post: 16th August 2011, 16:39
  4. VECTRA AUTO STICKING IN 5th GEAR
    By cosjon in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2009, 20:38
vauxhall vectra automatic 3rd 4th 5th gears incorrect
vectra c gear shift
