Thread: Removing Facelift V Grill
    Oct 2007
    Ripon
    Default Removing Facelift V Grill
    I am looking at getting a vxr v grill painted up and put on Sri veccy.
    I understand the bumper needs to come off (may get some siggy fogs and do at same time) , how easy is it to get the chrome v grill off? Looked through threads but no real clue on the job.
    Any info??
    Regular Member GTS's Avatar
    Oct 2010
    Poland
    Quote Originally Posted by robdd1 View Post
    Any info??
    Nope, you don't need to remove bumper. The chrome v-grill has got plastic clicks all around. You must be careful because they're very fragile (especially around the badge). Use flat screwdriver or knife but pay attention not to damage chrome paint.
    Full Member spennny's Avatar
    Blantyre
    If your doing the surrounds also mate take the bumper off, its a 10 min job, you will access the V grill clips better from the back , ensuring that they dont all break
    Take your time and dont snap any
    Regular Member dannydm1's Avatar
    Jan 2008
    leeds / wakefield
    id suggest removing bumper. bumper comes off realy easily. will make the job a lot easier
    WGAF#5
    as said remove the bumper for far far easier access and give yourself plenty of time for this job . ... its a pita i recently read a nice tip that i wished i had used ... on the two i have now done
    get a bag of cable ties and each time you pop a clip stick a cable ties tapered end into the gap to prevent it from popping back in ... there plastic so wont cause any damage ...and as you work your way around then they will help hold the parts under tension and make it easier as there popping out ....
    good luck take your time and dont attempt if you feel stressed in any way ... and dont forget the pictures
    before and during and after
    Oct 2007
    Ripon
    Cheers for the tips ....
    Looking at new V and getting that painted, the chrome V will not be reused so not to worried about them to much.
    scottish region
    Spend the extra 10 mins and remove bumper really easy
    WGAF#5
    but you have to make sure you take it out without damaging where the new v grille will go back in as the lugs still need to be able to hold the new painted grille ... and the bottom silver trim is the last bit to go back in
  1. For Sale: Facelift front grill & V-grill and Signum load cover
    By gibbon7000 in forum Parts for sale
    Last Post: 17th July 2012, 19:13
  2. Removing the chrome v from front grill
    By Ralphwells1967 in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2012, 00:42
  3. preface irmy grill.......removing strip
    By Ben_ in forum Styling
    Last Post: 13th July 2011, 20:20
  4. Removing top grill an 'V' from bumper
    By petersaxon in forum Bodywork & Interior
    Last Post: 10th June 2009, 20:23
  5. removing facelift v grill
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2007, 18:01
vectra c facelift grill removal
https:www.vectra-c.comforumshowthread.php143723-Removing-Facelift-V-Grill
vectra c grill off
vectra c facelift removing v girlle
how to remove v on front of vectra
how to remove front grill on 2007 vectra
how to remove grille from vectra c
how to remove vauxhall v grill
replacing vectra facelift frt grille
temoving grill of front bumper vetra
vectra c grill removal
remove grille off a vectra c uk spec
how to remove front grill vauxhall vectra
vauxhall vectra c facelift grill
vectra c facelift front grill
