Results 1 to 10 of 20
Thread: 2 stroke oil - 1.9 CDTi 150
    Jul 2009
    Brighton
    Default 2 stroke oil - 1.9 CDTi 150
    Well I've just put 200ml of 2 stroke oil in my Siggy.
    Read so many threads saying do and don't, so will try for myself.
    Car has just had a service, so I will also check on the condition of the oil.
    The tso is JASO FB low ash, so shouldn't mess with the dpf.
    Anyone else put tso in a 1.9 150?
    BTW mines a 2006
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Should be fine. Such a low concentration won't thicken the diesel any more than it being a rather cold winters day. Should actually burn a bit cleaner which will help the DPF too. Mine's a DTi so can't comment on the CDTi's but hope you see a change!
    stockport
    Arrow
    Quote Originally Posted by DHobbs View Post
    BTW mines a 2006
    Use it all the time,have done for the last six months with no problems.Engine seems to run smoother and I never have a smoke issue,even under hard acceleration.FELIXX.
    Jul 2009
    Brighton
    I've only driven it once since adding tso. And that was just to get fuel. So not seen any difference yet.
    As I mentioned, mines a 2006 Siggy, so not sure if I've got the teflon coated pump etc now the sulphur content is reduced in diesel.
    Will also monitor if the DPF needs regening more often or not. I suspect it should be less, but will report my findings.
    Regular Member J18BES's Avatar
    Malvern
    Trim : Sri 150
    Engine : 1.9 CDTI
    Mileage : 115000
    I have being doing this for past 2 months and have found the engine alot smoother and alittle quieter, also it has stoped smoking from cold and under acceleration. also i have seen my mpg go up a very little about 1/2 mpg
    Jul 2009
    Brighton
    I've now done 150 miles with tso. Can't say I've noticed any difference.
    MPG still the same.
    Performance wise, slightly better (placebo maybe), but just had a service and a squirt of carb cleaner into the throttle body.
    No change to smoke though as I've got the dreaded DPF.
    I'll carry on trying this, at least until I've used the litre I bought! Maybe I'll notice the difference if I stop using it!
    EVERYWHERE
    I tried it in mine, too. I got 10 mpg extra, the gear change was better, and the car was much faster, and also rode the bumps better. Can't think why Shell, BP or whoever never caught on to this little trick?
    I had read on a motorcycle forum that it can gum up the piston rings if it's used in anything other than a frequently rebuilt 2 stroke engine. So the guys with four stroke motorcycles don't touch it.
    lincolnshire
    i did this and never noticed a difference on the 120 i had
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    I tired it on my 1.9 150 and a family member s 2.2 dti, didnt notice a difference on either but both were in good working order anyway
    Regular Member G4GAV's Avatar
    Bristol
    iv not heard of this. so what do you do just chuck in say 200ml in a full tank and away you go ?
  1. 2 stroke oil.....wow!!!.
    By felixx in forum Diesel Engine related
    Last Post: 28th May 2015, 06:24
  2. Two stroke oil questions
    By Big Sig in forum Diesel Engine related
    Last Post: 1st March 2012, 21:30
  3. Two Stroke
    By Homer in forum Engine & Drivetrain
    Last Post: 10th June 2011, 08:00
  4. I think I almost had a stroke......
    By robster23 in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2010, 23:14
  5. Heat stroke
    By JuzzyD in forum General Chat
    Last Post: 7th August 2007, 21:12
2 stroke oil in diesel vectra
what oil for diesel vectra
2stroke in vauxhall zadira cdti
insignia bad batch of diesel
cdti with 2 stroke
2 stroke in cdti
2 stroke oil in cdti
using 2 stroke oil in fuel in a cdti
astra 1.7cdti 2stroke oil
astra 1.7 cdti 2 stroke oil
2 stroke oil in diesel fuel
cdti with 2 red letters
two stroke vauxhaul insignia
i get 300 miles a tank my vectra c 1.9cdti
2 stroke oil in vectra c
two stoke oli on vectra b
2 stroke cdti
vectra cdti 2 stroke oil
2 stroke oil in cdti 15o
