Results 1 to 3 of 3
Thread: sri 120cdti difficult to start in morning
    Regular Member Turbomanrony's Avatar
    Sep 2010
    LEEDS
    Default sri 120cdti difficult to start in morning
    i have 2005 sri cdti 120 it takes at least 30 secs to start on morning, then its fine through the day but some times does need few turns to start it.
    if any 1 can help would be good getting to the bottom of it
    i have changed the heater plugs and done a full service but still the same.
    Apr 2011
    Toulon, France
    That sounds like you battery Turbomanrony
    I have seen a few threads on here where people have changed their battery and morning starting has improved
    My vectra had a new battery just before I bought it. It has recently been parked for 6 weeks and started first time , only turning over for about 5 seconds before starting
    Jun 2011
    Elland
    Get the battery checked out
    You can do this at SYBS, near Armley gyratory - I have had a lot of dealings with the guy and he's a decent fella - he won't rip you off. If it's a good battery, he will tell you Tell him Charlie with the boat says Hi, if you see him!
    If it's OK, does the car start OK if you let the priming pump run for a bit first? The 1.9s have a pump in the tank and you should be able to hear it running. Let the pump run, then strat the car. If it then starts OK, then you might have a problem with fuel running back to the tank.
    You might pick up some tips here: http://www.vectra-c.com/forum/showthread.php?t=142660
  1. Vectra 2.0 DTi difficult to start when warm
    By C470 in forum Engine & Drivetrain
    Last Post: 11th July 2012, 16:35
  2. Vectra 2.0 Dti Difficult To Start
    By dan9895 in forum Engine & Drivetrain
    Last Post: 18th April 2012, 16:30
  3. CDTI 120 difficult to start
    By matt_harw in forum Engine & Drivetrain
    Last Post: 14th November 2011, 21:48
  4. 1.9 cdti 120 difficult to start and low power under 1500 revs
    By johninthetoon in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2010, 07:46
  5. difficult to start in the morning
    By patrick1062 in forum Engine & Drivetrain
    Last Post: 18th July 2009, 20:32
