Thread: Towing with a vectra cdti 150
    Jul 2011
    wolverhampton
    Default Towing with a vectra cdti 150
    Hi i was wondering what the Vectra was like at towing,i have not had the van on the back yet since i brought the car. Originall got the car as a stop gap before i got the 3.0 as my previous car blew the engine on the way on holiday. Problem is i like the Veccy so much i want to keep it providing it is ok at towing.
    Any one have any problems towing with one?
    thanks
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    i should think the 150 cdti should be excellent towing my 2.0dti was spot on so more power and torque should be spot on
    Regular Member RobW's Avatar
    Tain - Easter Ross
    http://www.caravantrekker.nl/whattow...l&serie=Vectra
    Few reviews on there, albeit for caravans but the gist will be the same
    Regular Member coooky's Avatar
    May 2011
    washington
    my 130 tdci ghia mondy was a great tow car so the veccy should be great but watch what weight van you get
    here you go lets you know if your car will pull it safely
    http://www.whattowcar.com
    Sodding Typical on Sea
    It does put an additional stress on the DMF but as long as you avoid abrupt harsh acceleration/deceleration cycles the car itself is very capable and has a massive wall of torque at the right place for towing.
    Jul 2011
    wolverhampton
    Reading the reviews it seems a nice piece of kit for towing,its been nearly ten years since i towed with a car as i have always had 4x4.
    My van is only 1298kg fully laden so should be no problem.
    My other car gave way going up birdlip in the cotswolds with the van on.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    My boxed 2.2 dti has 155 brake (280 lb ft torque) and pulls my 1250kg Swift Corniche with ease. You'll need to keep an eye on nose weight and the rear shocks will need to be in tip top condition to prevent grounding but apart from that it'll be fine
    May 2007
    West Yorkshire
    I have towed with 2 x 150's both facelift estates, one manual sri and one automatic elite. Both towed with no problems.
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    I tow our swift accord 1332kg mptlm with our 2.0 dti, pulls it with no problems.
    Leicester
    As said, you will be fine. My first 150 was an 04 pre-facelift and was fine, the second was a facelift with an EDS re-map and towed all over France with it.
    My van has a max weight figure of 1455kg's and it was effortless. Both had the 19" Snowflake wheels as well.
  1. Max towing weight - CDTI estate
    By zafira in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2011, 15:51
  2. Signum V6 cdti Towing capacity
    By robfal in forum Vectra C / Signum Troubleshooting
    Last Post: 7th August 2009, 21:03
  3. Vectra V6 CDTi Auto -Towing Limit/Oil Cooler
    By solarvec in forum Engine & Drivetrain
    Last Post: 20th March 2008, 15:15
  4. SRi XP CDTi 150 Estate Towing????
    By HA54SYM in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2007, 11:27
