Thread: 2.2 with a rattle
    May 2008
    RAMSGATE
    Default 2.2 with a rattle
    Hi all my 2.2 non direct has started to give a rattle noise when started up, lasts for about 3 seconds then stops. Any ideas?? Thought it might be the chain.
    Thanks in advanced
    morecambe
    32 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Yes it does sound like the chain mate
    Regular Member slinky270306's Avatar
    Aug 2010
    Devizes
    Promise you its the chain and perhaps tensioner.
    Through Vauxhall you're probably looking at £800/£900 to resolve.
    My 2.2 does exactly the same thing every so often. Been doing it for yonks now.
    May 2008
    RAMSGATE
    I'll do it myself I think, cheers guys
    6 Post(s)
    Quote Originally Posted by slinky270306 View Post
    Through Vauxhall you're probably looking at £800/£900 to resolve..
    Wasn't that much when Vx changed my chain. And I then got a 70% goodwill gesture because the tensioner was faulty, but they also wanted to change the chain to be on the safe side.
    http://www.vectra-c.com/forum/showthread.php?t=104735
    Aug 2010
    Devizes
    I've been to my dealers (Platinum Vauxhall in Trowbridge) and thats what they said to me.
    They said keep an eye on it and if it gets any worse go back. Thats was at least 2 yrs ago. Sometimes it does sometimes it dont rattle but thats why they probably did yours due to the fact it was doing it whilst it was within it's warranty.
    Mine wasn't. Still will keep an eye on it like always and if it gets worse, bye bye car because wont be worth getting if fixed.
    6 Post(s)
    It's a know issue with the tensioner which is why Vauxhall have a field remedy recommending changing it to the one they fit in the 2.0 turbo engines in the event of failure. I don't know the field remedy number offhand, but if you can find it, then it might be worth reporting back to them about it. Sounds like they're just covering up.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Not saying it's not the chain, but if there's an issue with the tensioner/pulley (Common problem on the 2.0T which has the same chain drive)
    Part numbers are in THIS THREAD(last post)
  1. DMF rattle
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2013, 13:31
  2. Bad rattle!
    By heheshamon in forum Bodywork & Interior
    Last Post: 16th April 2010, 20:37
  3. rattle rattle
    By jaytops2k1 in forum Troubleshooting
    Last Post: 10th September 2009, 19:07
  4. A rattle at 70
    By Jezza181 in forum Engine & Drivetrain
    Last Post: 25th March 2009, 08:02
  5. Rattle rattle boooooom!!
    By Triple Trouble in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2006, 08:44
