Could this be drop links or somat else?
Had both the drop links on my Zafira replaced recently. Knocking like a good'un over every bump.....
was it knocking before or after the drop link change??
It was before. It started only over big bumps but the road I live up is unadopted and quite uneven and it got worse. Just before I got them changed the banging was all the time. Changing them cured it. Had one done, then 3 months later the other went!!
Mine was the drop links and now the noise has gone .
Droplinks are the most common things to knock on the suspension I always replace the drop links with updated ones from Saab bit more expensive but will last a damm site longer
