Thread: Knocking from front end not loud but noticeable
    Worksop
    Default Knocking from front end not loud but noticeable
    Could this be drop links or somat else?
    ijk571
    Guest
    Had both the drop links on my Zafira replaced recently. Knocking like a good'un over every bump.....
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    was it knocking before or after the drop link change??
    ijk571
    Guest
    It was before. It started only over big bumps but the road I live up is unadopted and quite uneven and it got worse. Just before I got them changed the banging was all the time. Changing them cured it. Had one done, then 3 months later the other went!!
    Regular Member Driver0069's Avatar
    Oct 2009
    South Yorkshire
    Mine was the drop links and now the noise has gone .
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Droplinks are the most common things to knock on the suspension I always replace the drop links with updated ones from Saab bit more expensive but will last a damm site longer
  1. Loud ticking/knocking
    By rob123 in forum Bodywork & Interior
    Last Post: 31st May 2010, 18:19
  2. Loud knocking from Left Rear Wheel
    By thegoldenbullet in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2008, 18:46
  3. Loud creaking from front of car
    By mike12 in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2008, 23:49
  4. V.noticeable Rumble/vibr From Front At 70+mph
    By stephmc51 in forum Suspension, Wheels & Brakes
    Last Post: 16th November 2008, 17:27
  5. Loud knocking noise...
    By haegwani in forum Suspension, Wheels & Brakes
    Last Post: 15th June 2007, 07:54
