Hi all,
Tried searching but couldn't find anything. So my question is, where is the factory fit sat nav aerial? My CD70 (when using the nav) has suddenly stopped working, saying no GPS signal.
Cheers.
Hi all,
Cheers.
It uses the radio aerial/base on the roof i believe.
I'm sure it's built in to the aerial base. To access it to check the connection you'll have to drop the roof lining- pull back door and boot seals, remove c pillar trims, there are 3 strong velcro pads along the top of the boot. Have you checked the connection on the back me the stereo?
Beaten to it .
Thought as much...Not an easy job then I'll have a look tomorrow. Have had the CD70 out and that looks OK wrt the connectors.
Thanks for your comments though.
The wiring runs down from stereo to a big block connector in drivers footwell,it then runs up A pillar to rear aerial HTH very easy to remove and inspect as i retro fitted a nav aerial into my old vectra
Irmscher Insignia CDTI 130
Cheers Bigmac. I disconnected the battery last night before i went to bed and reconnected this morning and then reset the windows... The car thought i was in the middle of the north sea at first but then zoomed to where i live! Job sorted. No need to dismantle the car - thank god! Puzzled as to why it went ga ga though
