Thread: Cruise control issue
    Jul 2011
    london
    Default Cruise control issue
    Hi,
    My 04 vectra has a strange problem with the cc, it will engage and work for anywhere between a few seconds and a few minutes and will then disengage randomly. it takes a few attempts to switch it back on again, but once on it will work for a bit then switch off again.
    Ive tried holding the clutch and brake pedal up with my feet while it was on, didnt seem to make any difference.
    Anyone know a good place to start looking into this?
    thanks
    Jun 2011
    Elland
    Chances are the contacts between the stalk and the CIM are dirty or knackered.
    Mine does the same - it's a common fault!
    The stalk can be removed by unseating the rubber gaitor and pulling the stalk out. You will have to pull quite hard! The contacts can then be cleaned and inspected. Sometimes a clean will do. Sometimes the contacts inside the CIM have become flattened down. One member managed to lift the contacts up a little inside the CIM and that worked. Looks fiddly and my fingers don't do fiddly very well! I put a little dab of solder on the stalk contacts and this worked for a while. I haven't yet been bothered to find out why the mod has failed - perhaps the soft solder has worn down.
    To see whether it's likely the CIM contacts, drive the car and apply a gentle pressure on the stalk away from you. If the CC engages normally (with pressure maintained), try applying pressure on the stalk towards you. If the CC then disengages, it's the CIM contacts.
    Try using the forum search, as there are probably other tips on this
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved
    Irmscher Insignia CDTI 130
    Jul 2011
    london
    Thanks for your reply!
    Glad to hear its a common fault and possibly a simple fix, ill try cleaning the stalk contacts as you've mentioned. thanks.
  1. Cruise control issue
    By Marky in forum Vectra C / Signum Car Chat
    Last Post: 6th August 2012, 12:29
  2. cruise control issue help
    By chris1984 in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2012, 19:25
  3. cim no way (cruise control issue)
    By unreal_event_horizon in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2011, 14:21
  4. Cruise control Issue
    By hopkinson06 in forum Electrical & ICE (including SatNav)
    Last Post: 18th February 2009, 02:49
  5. Cruise Control Issue
    By TheWildHaggis in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2008, 14:59
