Thread: Brake pad size please
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Default Brake pad size please
    hi lads and lassis just need to no what size pads front and rear i need for my 2.2 direct auto siggy thanks
    Full Member Big Sig's Avatar
    What size pads? Do you mean disks?
    Eurocarparts will search and tell you based on your reg number, although I believe there is a sticky on here will all the sizes listed somewhere.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    no the local part place said there is two sizes listed and ok will try that cheers mate
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    You will have 278mm rear discs but the pads are the same as the 292mm rear discs and you will have 288mm fronts if your car is standard.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    thank you very much cheers mate
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by paulhb View Post
    Although most people refer to the fronts as "285", rather than 288....lol
    http://www.vectra-c.com/forum/showthread.php?t=139088
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Oh my bad 3mm out well at least it wasn't 302mm I said
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Although the 285 and 302s have the same pads too
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Ok i surrender think It's time to go and rest my head
  1. Brake Disc Size
    By hodge725 in forum Suspension, Wheels & Brakes
    Last Post: 2nd November 2012, 17:41
  2. brake size
    By john-d in forum Handling & Braking
    Last Post: 22nd January 2010, 22:01
  3. brake size
    By decks in forum Suspension, Wheels & Brakes
    Last Post: 3rd May 2009, 13:20
  4. what size are my brake discs???
    By dannydm1 in forum Handling & Braking
    Last Post: 27th October 2008, 21:09
  5. Which size brake discs????
    By henocsr in forum Suspension, Wheels & Brakes
    Last Post: 21st June 2008, 09:52
