Results 1 to 10 of 16
Thread: Bicolour high intensity 8mm led's
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Default Bicolour high intensity 8mm led's
    hi all, needing some special little led's for my current mod in progress. been hunting the net but cant find them. dont even know if anyone makes such a thing. but thought i would post up here for folks that have had dealings in such electrical items.
    im looking for 8mm bicolour high intensity led's white and amber. any body know if there is such a thing. i have sent a few emails to companys but not heard anything. dont know if they think im off my head or not but its for a serious mod idea im working on.
    cheers, Tim
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    i dont think they do bi colur led to behonest mate
    Nov 2010
    BRECHIN
    i can get bicolour led so i know they exisit. but the ones ive found there small things normally 3mm and red and green
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    i stand corrected no then lol
    Regular Member Reevo's Avatar
    Nov 2010
    Leicestershire
    Tried crazy leds?
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    Nov 2010
    BRECHIN
    cheers chaps, got an email sent to crazy leds but still no reply. been a week
    this is the sort of thing i need only in 8mm and a hell of alot brighter looks like my 1 off mod aint gonna be happening
    they work by the middle pole being - and the other 2 poles + or the other way round cant remember, by putting voltage thru 1 pole gives you 1 colour and thru the other pole another colour.
    was wanting to do my drl mod at the front but also allowing them to work as extra indicators. so turning right the right drl would flash white and amber. would be a really funky mod got all the wireing sorted but cant track the correct type of led required. rather frustrating. wonder if a company could make them up
    Jul 2009
    The Rift, Cardiff
    what about smd's? They're bright and small enough to possibly get 2 side by side.
    Aug 2009
    Trim : SRI
    Mileage : 50000
    The reason you cant fins white/amber leds is that the diodes are differnant and cant be mixed, but there is a way you can do it,
    What you need,
    8mm Acrylic rod http://http://www.ebay.co.uk/itm/8mm...item5ada1843e6
    3mm Ultrabright 15000mcd white leds http://www.ebay.co.uk/itm/10-x-3mm-U...item2a1241c136
    3mm Waterclear 8000mcd Amber leds http://www.ebay.co.uk/itm/3mm-Waterc...item45f199507d
    And put them together like this, Hope this help you out.
    Nov 2010
    BRECHIN
    now thats a very good idea
    the rod links not working. ones im looking at are solid. could you post up the rod again please, cheers
  1. H I D S ( high intensity dazzle shi!!!!!!@@@)
    By dannyjpuk in forum Electrical & ICE (including SatNav)
    Last Post: 19th December 2011, 09:59
  2. Help - High idle (1000 rpm) and high map reading
    By roswell in forum Engine & Drivetrain
    Last Post: 5th April 2011, 21:49
  3. Under Car LED's... What do you think.
    By Leemarksmith in forum Styling
    Last Post: 10th January 2011, 18:54
  4. smd led's
    By baz2003uk in forum Electrical & ICE (including SatNav)
    Last Post: 8th July 2009, 22:56
