Results 1 to 10 of 24
Thread: thermostat what could it be
    Regular Member dannyjpuk's Avatar
    Jan 2010
    northumberland
    Default thermostat what could it be
    Morning all (update from a previouse thread)
    I have had my 57 plate sri 1.8 for about a month its done 15k i noticed that the thermostat hardly moved even on long journeys ( or if it did move it droped ) anyway i took it into the garage on Wed they replaced the thermostat he showed me a little black tube kind of thing.... i said is it fixed then and he said should be so i thought great .... i have done a few trips it does move but not what it should be ... like this morning i hoofed it to work 10miles and it dident even move..... any ideas whats next?
    West
    try replacing the coolant temperature sender
    Jan 2010
    northumberland
    ok mate ill tell them to do that next
    Or do some actual fault diagnosis instead of randomly changing components... Take the sensor out but leave it connected, and put the end in a cup of recently boiled water. If the gauge reads then you know it works, and you may have an air lock somewhere if they didn't bleed the system fully...
    Regular Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Quote Originally Posted by dannyjpuk View Post
    What do you mean?
    As far as Im aware you cant just change the internal thermostat on the vvt you have to chnage the whole unit, so does it look like they have changed the thermostat? If they have at this time of year it should be right up to temp within 5 minutes due to the far higher ambient temp.
    Jan 2010
    northumberland
    What do you mean?
    he showed me the black part on this....
    http://www.ebay.co.uk/itm/Vauxhall-V...item4cf75664e5
    he said thats what they replaced
    but its done nothing this morning i booted my car into work 10miles and it didnt move
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Thats a vec b one, heres what your should look like.
    http://www.ebay.co.uk/itm/Vauxhall-T...3#ht_810wt_932
    Think they have just changed the sender unit, you need to get the whole unit changed, they are expensive on the vvt, maybe why they just tried the sender first. I'll have a quick look, think you can pick up a whole unit for around £65.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Going by that pic, they haven't actually changed the stat at all... just a hose connection. The stat itself is the circular bit in the middle - so if it had failed as you suspect, then it's still sat in there, wide open, doing nothing but taking up space and costing you money as it'll not be helping to bring the engine up to correct temp so it can work at it's best.
    The sender is the thin gold coloured cylinder to the bottom left of the pic.
    The VVT boys on here should be able to tell you how to change the correct parts and how easy/hard it is.
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    AS I understand it, the temperature gauge is not moving, and you suspect the thermostat. Normally I'd do what Penfold 101 said with the sender unit, and if possible, do the same with the thermostat itself, to see if it opens and closes.
    Generally is thermostat, but not always, sometimes it's just a bad connection somewhere.
  1. thermostat
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2012, 18:08
  2. Can anyone tell me what a thermostat does?
    By twinxster in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2012, 22:03
  3. Thermostat?
    By killa_uk in forum Engine & Drivetrain
    Last Post: 31st January 2012, 18:35
  4. can it be anything other than the thermostat
    Last Post: 20th January 2011, 22:36
  5. thermostat or thermostat kit?
    By IA76 in forum Engine & Drivetrain
    Last Post: 24th September 2010, 11:33
