Results 1 to 10 of 21
Thread: Swirl flaps problem i think
    Jul 2011
    wales
    Default Swirl flaps problem i think
    Hi guys just noticed the bar that connects to little washer things has come off how do these go back on and its been off i would say for about 6 weeks. Since my probs have started. Would i need a new inlet manifold now?
    Regular Member coooky's Avatar
    May 2011
    washington
    Jul 2011
    wales
    Thanks mate.
    Jul 2011
    wolverhampton
    Works a treat mate done mine like this and done over 500 m since
    Jul 2011
    wales
    Common problem then?
    Jul 2011
    wales
    Do i need to take inlet off aswell to do it?
    Jul 2011
    wolverhampton
    No mate, i just cleaned the bar using carb cleaner before glueing the caps on,just make sure the swirl flaps are moving freely. The 3rd one across on the right is driven by the actuator so it will not move until u rev the engine.
    A bit of WD40 does a good job of cleaning the muck off the area. If you pull off the glow plug leads it makes life better to get at them.
    Regular Member martyboy's Avatar
    erskine
    Default Inlet.........
    Hi mate,
    My car in garage just now because of swirl flap failure. tried repair but no good and oil was shooting out of the 3rd and 4th from the right. Job requires new inlet manifold, gasket, drive actuater and possibly tech 2 to set up. Arnold clark quoted £1500 approx to do whole job which i opted NOT to go for, then a call back from them quoting £976 to repair after "loyalty discounts" taken into consideration.(STEALERS) never a truer word said.
    My local mechanic is now doing the whole job for £620 which is better for me.
    Hope you can solve yours with the quick fix.
    May 2011
    washington
    Quote Originally Posted by martyboy View Post
    for a part that costs £160 and you dont need a new drive actuater or Tech2
    Engine : 1.9 CDTi
    Most of it is labour charge as it takes a good 6 hours to do.
    Also worth getting a cambelt and water pump done at the same time whilst its in bits if its near a belt change.
  1. hello to all and swirl flaps
    By hasbin0796 in forum Introduce yourself.
    Last Post: 11th March 2012, 16:31
  2. swirl flaps
    By justin32 in forum Engine & Drivetrain
    Last Post: 7th January 2012, 18:34
  3. Swirl flaps
    By Petemate in forum Engine & Drivetrain
    Last Post: 12th October 2011, 16:46
  4. swirl flaps?
    By mickyblueyees in forum Engine & Drivetrain
    Last Post: 20th January 2011, 18:01
  5. swirl flaps
    By rob888 in forum Engine & Drivetrain
    Last Post: 6th November 2007, 21:15
