Thread: Help please please please Engine flat spot
    Jul 2011
    wales
    Default Help please please please Engine flat spot
    Hi guys, got a problem with my cdti 150, its got a flat spot but wen i say flat spot it goes then will stop for a split second and sort of jump back on to the turbo, ive just cleaned egr valve. It also jerks or miss fire sort of thing when on 1500-2000 revs. Could it be related?
    Any help would be hugely appreciate
    Thanks guys.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Has your third injector wiring loom been changed? common problem.
    Regular Member gaz1965's Avatar
    Mar 2011
    Putney London
    Trim : SRI 150
    Engine : 1.9 CDTI
    How can you tell if it's been changed?
    Middlesex
    Trim : SRI
    Mileage : 100k
    basically the third injector along will have a different plug... ive posted a pic somewhere I think - gimmie 5 mins , will search.
    Jul 2011
    wales
    Hi mate yes this been done but noticed the bar what connects to the swirl flaps has come off are these easy to put bk on?
    Jun 2011
    Elland
    There is a how2 about this - and to repair the bar for about £1 with tap washers
    Jun 2011
    Elland
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved to correct section
    Irmscher Insignia CDTI 130
    Regular Member ONEMINUTESILENCE's Avatar
    Jul 2010
    Skipton
    I had the same problem, mine hesitated at 1800rpm, EGR was replaced less than a year ago. I unplugged EGR and hesitation gone. Try doing that 1st, if it resolves the issue blank it off, just try a search on EGR blanking there are loads of posts/threads
    Jun 2011
    Elland
    But first try repairing what you know is broken (swirl bar fallen off). See how that goes, then look at other areas
  1. Flat spot
    By marc vectra sri in forum The 'Off Topic' room
    Last Post: 12th August 2012, 19:38
  2. flat spot but different
    By Derek Mc in forum Engine & Drivetrain
    Last Post: 28th July 2012, 11:40
  3. Flat spot!
    By bigknill in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2009, 09:43
  4. flat spot
    By surreyl31 in forum Petrol Engine related
    Last Post: 16th July 2007, 18:41
  5. Flat spot
    By mriley60 in forum Engine & Drivetrain
    Last Post: 3rd July 2007, 14:15
vauxhall vectra estate flat spots
