Thread: Brake pad warning light
    Aug 2009
    Default Brake pad warning light
    Hi all,
    Twisted brake pads sensor wires as said in howto (Brake Pad Sensor Quick Fix) , but warning light still light up. Any ideas?
    Car: Signum 2003.
    Thanks.
    Might be a silly question but did you strip the insulation back on the two inner wires before twisting them together?
    Aug 2009
    Quote Originally Posted by Rapala View Post
    Yes, of course. Also tried to put paper clip into connector and shorten contacts.
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    i assume this is on the ns/f?
    try removeing the link cable between the sensor wire and the harness on the car and put ya paper clip in there to see if it goes out. not sure which pins tho. should be 4?????? i think????
    as had a problem with my abs sensor and it was the link wire inbetween that was shot
    Aug 2009
    Quote Originally Posted by TimTay View Post
    Tried all possible variants. Nothing helps. Decided to cut out the connector from the car and twisted wires together (yelow and brown). No result. Still have warning light.
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. 3rd brake light warning
    By madvenny83 in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2010, 07:26
  3. Brake warning light
    By dandsi in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2010, 16:32
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. Brake warning light
    By scar_vectra in forum Suspension, Wheels & Brakes
    Last Post: 23rd June 2007, 12:48
