Results 1 to 10 of 23
Thread: Grounding for HID Ballast?
    Regular Member the-converter's Avatar
    Australia
    Question Grounding for HID Ballast?
    I recently bought a canbus hid kit.
    On the ballast, it states that you must connect the ground strip to the metal part of your car.
    Is this connection necessary?
    What is the purpose for the grounding?
    If I skip this procedure, what will happens?
    scottish region
    They ballasts are crap I'm affraid to say as they should power off the original.connections
    Australia
    Quote Originally Posted by vectrac150cdti View Post
    What do you mean they should power off the original connection?
    scottish region
    It should plug in the original bulb connections the ones you need to power off car and ground don't last long
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    that says its a canceller????? are they combined with the ballast?
    Australia
    Quote Originally Posted by TimTay View Post
    Here is the full picture.
    Australia
    This ground connection is like an extra grounding.
    Anyway, you will plug +ve & -ve plug from the hid bulb to the orignal bulb connection.
    I don't understand why they need this extra grounding.
    scottish region
    Ok no that seems ok but if it has extra grounding you would be safer to do it as it must be there for a reason bud
    Nov 2010
    BRECHIN
    the extra grounding would be because the ballast is metal would it not?
    save you getting a belt if sommit goes wrong inside
    Australia
    In this case, I better follow the instructions.
    Your are right.
    The ballast is made from metal case.
  1. HID ballast
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2012, 13:57
  2. How much Ballast? Arrrggggg
    By nibblitz in forum The 'Off Topic' room
    Last Post: 12th April 2012, 08:49
  3. Where do you mount your HID ballast?
    By the-converter in forum Electrical & ICE (including SatNav)
    Last Post: 14th July 2011, 20:20
  4. Grounding a car battery
    By Merick in forum General Chat
    Last Post: 4th June 2007, 14:30
