Thread: lights problem
    Regular Member coooky's Avatar
    May 2011
    washington
    Default lights problem
    i can turn on my main beam (hid conversion) and its fine turn the front fogs and the drivers light can sometimes go off turn the lights and car off turn the lights on fine then the main beam may go off
    any ideas ???
    morecambe
    39 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Lack of power mayb
    Do you mean dipped (low) beam?
    HIDs aren't really suitable for main (high) beam as they don't like to be switched on and off at frequent intervals.
    May 2011
    washington
    second setting i always call it main
    May 2011
    washington
    been out and replaced the 12000k with 6000k and i think the female spade connector coming from the lights isnt getting a good connection so im going to replace it and see if that works
    May 2011
    washington
    replaced the connector and the lights work fine with the engine off turn the engine on and the drivers light flickers a few times and goes off
    ordered a pair of capacitors from hids direct to see if that solves the problem
  1. AFL & ABS Warning Lights - Problem
    By spoons in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2011, 15:03
  2. Problem with my lights
    By kman247 in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2011, 10:10
  3. Interior lights problem
    By smoggy1955 in forum Electrical & ICE (including SatNav)
    Last Post: 30th March 2011, 14:11
  4. problem with rear lights
    By chris_20 in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2011, 21:38
  5. Lights problem - lights out
    By DarkNite in forum Electrical & ICE (including SatNav)
    Last Post: 13th September 2007, 16:30
