Thread: slight droming and a very little vibration noise.?
    wales
    Default slight droming and a very little vibration noise.?
    hi guys thanks for looking .my signum 2.2 petrol 04 just does not feel right i have looked and there are a lots of posts about noise but all different.i have just got mine went to work fine on way back slight droming and a small bit of vibration(very slight).free wheeling doing a hill no problem but put it back in gear a you know its there.the engine sounds a bit rattley.took it to get the exhaust checked thinking it could be that but it was ok.
    can you help it just sounds and feels different.
    Jun 2009
    South Coast
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    does the noise seem to come from the fromt or rear wheels or the engine area? I assume that if it only happens under load but is it more apparent in certain gears or at certain revs or speeds etc?
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    wales
    front m8 in all gears not rear tyres.it just startede on the way home from work.
    wales
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    Quote Originally Posted by signum driver View Post
    what make of tyres are they on the front?
    Jun 2009
    South Coast
    hmmm one of the 2.2 guys will hopefully step up with some advise soon. When was the chain replaced, i am not saying its that as that would be more of a rattle.. Is yours the Z22se or z22yh engine? What sort of milage does it have?
    Crap or worn tyres can cause such things but if your drone is under load rather than free wheeling then it points more to the engine/gearbox as being the most likely source..
  1. Slight whining noise
    By Jamesie82 in forum Engine & Drivetrain
    Last Post: 25th March 2012, 17:54
  2. window slight noise
    By dbgb25 in forum Bodywork & Interior
    Last Post: 20th July 2011, 10:50
  3. Slight Tapping Noise
    By spennny in forum Engine & Drivetrain
    Last Post: 28th March 2011, 21:03
  4. Slight rattle noise...
    By Stevie-B in forum Engine & Drivetrain
    Last Post: 4th July 2008, 13:22
  5. vibration/noise
    By murf2484 in forum Suspension, Wheels & Brakes
    Last Post: 29th March 2008, 08:26
vectra very slight vibration
z22yh engine vibration
