Thread: Vectra will not start 2 clicking sounds......
    Regular Member big nath's Avatar
    Jan 2008
    Irthlingborough
    Default Vectra will not start 2 clicking sounds......
    Car was working fine wednesday no starting problems but this moring no starting just 2 clicking sounds and nothing else.
    could it be the starter motor ?
    I have put up the sound on you tube @ http://www.youtube.com/watch?v=uJtdGt3jE2A
    Any help would be great as can't get to work before i start ringing garages and if it is the starter how easy to change car is a 1.9cdti 16v 2004.
    Thanks.
    havent heard the you tube noise but if it just clicks when you turn the key its usually either the battery or starter
    can you try and jump start it from someone elses car and then check the voltage across the battery
    Jan 2008
    Irthlingborough
    Can't jump start as in garage and to tight to push out, all the lights and elec windows are still working ok not moveing slow to show power low.
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    turn lights on and get someone to watch the lights as you try to start if they go very dim its the battery if they stay bright its the starter
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I assume you can get into the car..can you not push it outa the garage to jump start it?
    what about using a multimeter to check battery charge...
    Sounds like it's the starter motor - that clicking noise is usually the relay which connects the battery direct to the motor itself. If the relay is going but nothing's happening, then the starter's knackered...
    Jan 2008
    Irthlingborough
    Cheers will try later when the wife gets home from work.
    Jan 2008
    Irthlingborough
    How easy to replace starter looks like 3 bolts and power supply, not cheap at over £200 from euro parts.
    Glasgow
    I would usually say its the battery just going by experience BUT after hearing the video it sounds like the starter. Get a friend to tap the starter with a hammer whilst you are trying to turn it over.
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by markj23 View Post
  1. Plasticky clicking on engine start
    By Mattle40 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th January 2012, 21:12
  2. clicking/buzzing on start up 2.0dti
    By bembo449 in forum Vectra C / Signum Car Chat
    Last Post: 7th June 2011, 05:36
  3. Clicking noise on start up - 2004 Vectra Energy 1.8
    By Harry Hammer in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2011, 16:29
  4. Non Start just clicking ...
    By Led in forum Engine & Drivetrain
    Last Post: 5th November 2010, 19:30
  5. Clicking sounds when opening door
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2006, 05:25
vectra c wont start
vauxhall 1.9cdti engine just clicks
vauxhall vectra wont start just clicks
opel vectra c start problem diesel pump clicking
2005 vauxhall vectra starter relay
vectra c wont start just clicks
vectra clicking but not starting
opel vectura 2008 starter motor problem
only clicking when trying to start vectra
vauxhall vectra 54 ticking instead of start
vauxhall vectra c 1.8 wont turn over
vectra c 1.8 not starting
vectra diesel 2.0 2004 wont crank
vectra c relays clicking and car wont start
where is vectra c starter motor relay located
vectra c no start click noise
vectra c click
car will not start clicking sound
opel vectra c starter relay location
vectra starter motor problems
vauxhall zafira wont start just clicks
opel vectra clicking and wont start
vecta 1.8 diesel not starting
vectra c not starting
