Thread: hesitation between 1500-2000 rpm
    Wrexham
    Default hesitation between 1500-2000 rpm
    Hi,
    I am starting to get a bit worried about my vectra. It's a 1.9cdti 150. 65000 miles and 4 weeks ago had a lot of work done on it: service, changed inlet manifold, changed egr, changed cambelt.
    When I got it back, I noticed there was a hesitation/judder between 1700-1900 rpm. Brought it back and they updated the ecu software and changed the fuel filter. Still the same problem now. It's going back to the dealer next week, but I am starting to loose faith. I will be checking/changing the vacuum hoses this weekend. I will also check the throttle body and the boost sensor.
    Does anyone have any idea what else it could be. To me it looks like the new egr valve has messed up my car, as it runs fine when I unplug the egr valve.
    Map it out and blank it off. Problem sorted...
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Sounds like the new EGR valve is not seating quick enough or maybe the EGR was jammed shut before, so hiding a different issue? Stick a stronger spring on the valve.
    Wrexham
    Sorry, forgot to mention, I have never had any warning lights on.
  1. Replies: 9
    Last Post: 5th August 2012, 11:02
  2. 3.0 V6 hesitation 1500 rpm (solved)
    By yoladeuche in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2010, 10:59
  3. Cdti Hesitation At 2000 Rpm
    By CRAIG in forum Engine & Drivetrain
    Last Post: 9th October 2006, 13:29
