Thread: Car with spanner warning light
    Regular Member dbgb25's Avatar
    Aug 2009
    Margate kent
    Default Car with spanner warning light
    helloo justhave a trip to germany and stuck on motoway. Then my cooling temperature gon about 90 the car with spanner warning light comes and car went to limp mode . So I stopt swith the engine off and start again was fine till another traffic. So now Im switch the heating on and is no problem. Im still in germany .What you thinking there is the problem?
    Jun 2011
    Elland
    90 isn't excessively high, but it is about where the cooling fan cuts in. IF the ECU can sense whether the fan is actually working and it's not, then it MAY throw a wobbly. Try to verify whether the fan is actually working by letting the car idle until it cuts in...
    Aug 2009
    Margate kent
    Is it cooling fan have two speeds or just one cos its cuts in ....
    Jun 2011
    Elland
    At least 2 speeds. The V6 diesel has 3 - I can force them on with opcom. I'd imagine that speed 1 cuts in at one temp, speed 2 at a higher temp and so on.
    If you're idling and letting the temp rise, speed 1 will be all that is needed to bring the temp down again.
    Hard to be more specific without knowing what the spanner code is, but I'd say it is something to do with the cooling fan operation or the temperature sender. At least you can 'manage' the problem with using the heater! Just keep an eye on the temp gauge and make sure your coolant level is OK, if you're planning to fix the problem or find out what it is back in the UK!
    Aug 2009
    Margate kent
    Thanks m8!!! Will come back and check whats the code it is .
  1. Car with spanner warning light
    By Handles Sri in forum Engine & Drivetrain
    Last Post: 26th October 2012, 14:52
  2. Spanner Warning Light
    By TAL in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2011, 18:13
  3. Spanner warning light
    By olearysp in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 21:41
  4. car and spanner warning light
    By paul515 in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2009, 01:49
  5. Car with spanner warning light
    By DennisTheMenace in forum Engine & Drivetrain
    Last Post: 23rd March 2007, 07:47
