Thread: Vauxhall Frontera help
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default Vauxhall Frontera help
    following on from my sub 2k 4x4 thread I need a query answered......what engine does the 2.2 petrol frontera have and is it any good? From what i've read it's a belt driven engine
    its an x22se engine
    Rocker cover gaskets are prone to leaking but it takes minutes to change them
    Exhaust manifolds are prone to cracking.
    Head gaskets seem to be a common problem, usually between 60,000 and 100,000 miles. There may have been issues with the original gaskets as they seem to go towards the rear of the engine. It has been said this may be because the engine is tilted to the rear slightly.
    Due to it being a long stroke, high compression engine the con-rods and crank are under more stress then the 2.0 litre version so the bottom ends can be finnicky.
    Gudgeon pins can wear causing the pistons to go through the side of the block, regular oil changes will alleviate this problem. VX originally quoted 10,000 miles between services.
    Timing belts should ideally be replaced a bit sooner then the quoted 36,000 miles. Say 30,000 instead. The belt guide rollers are plastic and can disintegrate in spectacular fashion.
    hope this helps john
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Cheers bud, reading through that makes me think the v6 would be a better option
    I assum it's very closely related to the Vec's 3.2?
    the v6 is a superb engine , can be juicy because of the weight of the car but its so smooth its unreal
    also look into the 2.8 diesel
    what engine does the 2.2 petrol Frontera have?
    I swear that's the oddest question I've ever read on here......
    i didnt even notice that lol
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by Penfold101 View Post
    There is always one You know what I meant though
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    John when you mentioned 2.2 I assumed diesel in your pm.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by Gazza4 View Post
    I did think that later on . As I only do about 6 miles a day a petrol will do me fine. Nobody wants the 2.2/v6 petrols and prices are alot better than the 2.2 diesel.
    The 2.5tds and 2.8 are just a wee bit older than I want, remember i'm sacraficing my Vec for this thing
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    if it's the same lump that was in my old miggy then i can say it was a decent lump john, exhaust manifolds are a pain in the ass to say the least, keep em serviced regular and they can go forever like mine did and still is with 221k miles....
    Midlands Mod Shop - NFFC.
  1. vauxhall frontera
    By russ1969 in forum The 'Off Topic' room
    Last Post: 19th November 2010, 10:12
  2. Replies: 9
    Last Post: 14th October 2008, 23:42
  3. Bye-bye Frontera, Hello Vectra!
    By agadore in forum Introduce yourself.
    Last Post: 4th October 2008, 19:47
  4. The Antara - (the new Frontera)
    By Harry in forum Vectra C / Signum Car Chat
    Last Post: 15th August 2006, 21:10
  5. Vauxhall Frontera 2.0 Sport - Anything to look out for?
    By The Doc in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2006, 21:57
