Results 1 to 10 of 20
Thread: help help? steering shake/wobble
    wrexham
    Default help help? steering shake/wobble
    help? steering shake, mostly feels off side had it balanced tracked three times three sets of tyres and even changed the wheels it comes and goes its driven perfect for two days 200 miles+ no problem and its back again it seems to kick in at above 50 ish and when you steer to the right and also starts off on uneven road surface any ideas?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Have u checked the discs could be warped or the tyres have not bin put on correctly and balanced wrong
    lincolnshire
    drive shaft ?? gearbox or G.B mount ?
    wrexham
    Default shake/wobble
    three sets of tyres and a full set of wheels been on, discs look great and nothing on the pedal? plus it comes and goes
    wrexham
    if it was a driveshaft would it be ok for two days plus 200+ miles?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    No it's not a drive shaft that would be a constant wobble at all times and any speed
    lincolnshire
    i'm not speaking from vectra expo but a golf i sorted last year only wobbled with mid to heavy acceleration inputs , was fine at normal speeds . i'd have it dangled off a 2 poster and runn it in gear , that should help identify the culprit bud
    wrexham
    thx for your replys guys, i cant understand why it comes and goes you drive the same route three times and it would drive different each time it seems like once you steer to the right it starts it off and it becomes a heavy shake its just been lazer tracked and had a new dmf and clutch but it has not fixed the problem?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Maybe the sub frame has not bein put back properly
    lincolnshire
    Quote Originally Posted by dazy75 View Post
    right , so it did it before the clutch swap ??
  1. Steering wheel wobble..
    By Dane-10 in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2012, 18:05
  2. steering wheel wobble
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2011, 22:44
  3. steering shake/rumble?
    By vectra3.2dave in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2010, 19:38
  4. Steering wobble
    By Avenged in forum Suspension, Wheels & Brakes
    Last Post: 25th June 2009, 12:09
  5. Vibration/Steering Wobble
    By decho in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2007, 12:19
vauxhall vectra c driveshaft shak
