Thread: Signum ECU!!!!,Please help
    Mar 2011
    Swansea
    Default Signum ECU!!!!,Please help
    Hi all,the ECU on my Signum Elegance Direct 2.2 has broken beyond repair,the dealers are quoting £750 to supply and fit a new one,tho they did say that I could get a used one as long as the codes are reset and they would fit it for under £100,but i have had mixed opinions on whether I can put in an ECU from a Vectra 2.2.Anyone had similar experience as to whether I can fit one from a Vectra.Thanks in advance for any help.
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    Cant see why not. Engine ECU is just that, for the Engine, and the 2.2 is the same on both... Only thing to bear in mind is to make sure its from a Direct... and not a non-direct in case that matters...
    Engine : 1.9 CDTi
    Regular Member hagga's Avatar
    kingswinford
    Quote Originally Posted by plasma View Post
    As plasma says.... as long as the ecu has been 'divorced' from the other car it can be fitted and tech 2'd in
  1. Replies: 2
    Last Post: 6th October 2012, 23:09
  2. Replies: 5
    Last Post: 5th February 2012, 20:42
