Results 1 to 10 of 13
Thread: help on brakes need asap
    Mar 2011
    hull
    Default help on brakes need asap
    can anyone help me please. my neighboors signum 2l turbo burst a brake pipe a few weeks ago i replaced the pipes and bled it through i have since fitted new discs and pads all round and rebled them. now the problem is when the engine is off the brake pedal pumps up solid but as soon as you use the brakes with the engine running if you keep applying presure to the brakes the pedal will gradually sink to the floor. so after discusions with mechanics they all said the same that it was the master cylinder so i have replaced that today rebled the brakes and its still the same can anyone shed any light on what it could be. i dont know wether it did it before the brake pipes burst either so it might have been like it before hand.
    cheers
    ben
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Apart from that issue do the brakes work ok under normal operation? The Vec can suffer from brake pedal creep. Have you checked the vacum pipe to the servo?
    Mar 2011
    hull
    the brakes work fine slam on abs kicks in general driving brakes feel great and the car stops its just when you have stopped keep allping pressure to the pedal and it continues to the floor. checked all the vacume pipes and it all seems fine im just lost as to what it can be.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by vxr maniac View Post
    Sounds about normal to me mate. I take it you opened the nipple to push the pistons back in or did you just take the cap off the reservoir?
    Mar 2011
    hull
    no opened the nipples to push the pistons back so not to get any crap up the lines tried disconnecting the vacume and run the engine and the brakes stay solid and no spongyness so i dont know if theyve always been like that but they do work.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    normal ...when pressed hard the pedal works fine but if low presh is added and left on the rubber reaction disc in the system slowly crush's ....so no fault ..perfectly normal ...
    Mar 2011
    hull
    so why doesnt it do the same on my zafira vxr i have been told the abs pump needs bleeding but can only be done using tech 2 is this correct.
    cheers
    ben
    May 2011
    Kent
    I have just changed the discs and pads on my 08 vectra and it does exactly as you describe. Mine felt better before I touched them! I'm going to try and bleed them tomorrow incase there is any air in the system. The handbrake comes up too far too.
    Feb 2006
    dudley
    cheers
    ben
    a zafira isnt a vectra ....there not the same car mate unless you hadn't noticed ...!
    if you have beld it and no bubbles and the pedal is hard once pressed hard and only creaps when slight presh is put on it ..then it is ok ...
    Feb 2006
    dudley
    Quote Originally Posted by Rands100 View Post
    thats due to them beeing new and need beding in .....
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. It's going, ASAP!
    By MultiDropper in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2011, 15:10
  3. Need help ASAP
    By Liam1984 in forum Engine & Drivetrain
    Last Post: 31st March 2010, 15:10
  4. need help asap
    By davidlewis24 in forum Engine & Drivetrain
    Last Post: 27th January 2010, 21:54
  5. Need a New Car ASAP
    By JCB in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2006, 16:34
