Results 1 to 10 of 11
Thread: Blue smoke/Chugging!.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default Blue smoke/Chugging!.
    I know there's been a few posts regarding cdti blue smoke/chugging on start up, Has anyone solved this problem?, Ive been giving mine some attention trying to solve this, So far I know i have some faults but still trying to pin point the cause, I have a rattling/off balance dmf that does give an uneven run on tick-over, I have a small amount of black oil on the shafts of 1+2 glow plugs (checked & plugs are working, could be slight valve stem seal leakage), The thermostat I'm pretty sure is knackered (sticking open & running cold), If anyone else has this smoke & chugging have they checked there glow plugs?.
    north east
    Im pretty sure the chugging is the solder joints in the throttle body there is a how to somewhere for it, its also known for the throttle body to fill with oil just needs emptying out from what iv read.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Mine does it, funny you mention oil, mine too, has a rattling DMF and there is oil around the manifold flaps. Also noticed what looks like a drop of diesel sitting round injector seal no. 4. The chugging was a bit worse before thermostat was fixed too.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Ok sounds like there could be some comparisons!, Just to clarify, I fitted a new manifold some time ago & its all working fine, The swirls are bone dry as is the injector area, My throttle body has had the re-solder & has never had any oil inside of it, I have been venting to atmos to try & suck any oil residue from the intercooler(now running normal just to rule this out), My EGR is semi blanked with fiat oval & square gaskets, EGR is as new clean & working 100%, The dmf is rattling & feels as though its off balance on tick-over, As mentioned the thermostat is shot so maybe i should do that first anyway as its been a to-do job for some time now, The blue smoke's annoying & looks even worse with having twin exhausts.
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    i get this on my 2.2 dti aswel i think it is valve steem oil seals letting oil into the cyclinder when the car has sat a while ie. 8 plus hours
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    EGR is possibly at fault then.
    I doubt oil venting is going to affect idle in anyway, but if anything, it would make it idle smoother.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Ive got 2 egr's & swap them round when 1 needs cleaning, I clean them in oven cleaner & they come out brand new!, Ive had both on & still get the smoke, Not tried them without the semi blanking gaskets though as i never had the smoke for a long time after fitting them. I know this is quite common on some cdti's but its obviously no right but putting a finger on it is another thing. Cheers for the replys so far guys!.
    Quote Originally Posted by peadar View Post
    my money is on this
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Another vote for valve stem seals here.
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    classic valve stem symtoms
  1. blue smoke
    By Swedge in forum Engine & Drivetrain
    Last Post: 28th October 2012, 13:09
  2. Blue Smoke
    By Monkgti in forum Engine & Drivetrain
    Last Post: 30th July 2012, 16:31
  3. blue smoke
    By matt.d in forum Engine & Drivetrain
    Last Post: 26th June 2011, 11:34
  4. Chugging & blue smoke
    By s2yob in forum Engine & Drivetrain
    Last Post: 10th May 2011, 19:16
  5. 2.2 blue smoke
    By pyper_honda in forum Engine & Drivetrain
    Last Post: 3rd August 2009, 22:52
