Results 1 to 10 of 27
Thread: starter issues on signum turbo
    Jun 2011
    fife
    Default starter issues on signum turbo
    Hi folks,on my signum Z20let i got another odd one that i cannot for the life of me sort out.
    So fitted a new starter to the motor, because when you flicked the key with the old one it just kept cranking over.
    Now the starter does not turn at all and it is all powered up and ready.But at least it doesn't keep engaging.
    Could this possibly be down to the ignition housing where you put the key in being burnt or damaged.
    Cheers in advance.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Jezzy will be the man he knows that engine inside out
    Jun 2011
    fife
    cheers mate. look forward to hearing from him.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Is your battery ok?
    Jan 2010
    glasgow
    first of as said it the battery ok try it with a jump start or a known good battery if its still doing the same is it just making a clicking sound? is the engine turning over by hand ie engine off keys out and uses a ring spanner on the crank and make sure its turning over ok if so pull the starter out and use jump leads to test it from a battery not connected to the car to make sure the solenoid is not stuck and the plunger cog is throwing the way it should if it is is it the same as the 1 that was in the car? if so make sure the power is ok to the wires at the starter and it has a good earth
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    Did you buy a new starter motor for a z20let? Your engine is a z20net and quite different.
    Jun 2011
    fife
    The battery is fine. And it is the right starter for the motor.
    The problem seems to be that when you turn the ignition on to poisition 2 you hear everything power up and the throttle body and fuel rail fueling up. But when you go for the flick to position 3 there is no kick in from the starter, But you do hear the starter relay inside the car behind the glove box click, So i pressume that is switching power as it should. But you can get the motor to start buy using a power probe and manually hotwiring the starter with the ignition at position 2. When you do this the car runs as sweet as a nut. Now i'm starting to think that it could be the ECM or goosed relays.
    Does any body now if this is possible.
    Quote Originally Posted by hoochydady View Post
    Jan 2010
    glasgow
    that would be my next port of call mate make sure all the relays and fuses are ok
    Jun 2011
    fife
    Default signum turbo issues
    I have tried replacing all of the relays and the fuses are fine.hhmmmm Getting ratty with it now.
    I think i am gonna go down the route of fitting a starter button since the car starts fine when you fire power in to the solenoid with a power probe with the ignition in position 2 and it seams to run fine.
    What do you guy's think?
    cheers sandy.
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by sandy white View Post
    Sorry, only just seen this thread, having a read of it now.
  1. SRi Turbo running issues - help needed
    By johnsastra16v in forum Engine & Drivetrain
    Last Post: 22nd April 2012, 14:56
  2. SRi Turbo running issues - help needed
    Last Post: 4th March 2012, 17:15
  3. Signum Starter Motor
    By SignumDan in forum Engine & Drivetrain
    Last Post: 17th December 2010, 21:28
  4. starter solenoid or starter cdti 150 help!!
    By veralum in forum Engine & Drivetrain
    Last Post: 27th April 2010, 19:57
  5. signum 2.0T gearchange issues
    By Signatum in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2008, 05:14
