Results 1 to 10 of 16
Thread: Speedo Chrome Rings
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Default Speedo Chrome Rings
    Hey all,
    Wondering if someone knows the answer, I have a LS model with the most basic of speedo faces. I've seen other models have chrome rings around all four dials, are the rings something you can buy and stick on? I'm guessing it's obvious Vx won't but maybe there's an after market supplier that might?
    I really don't want to replace the speedo unit, anyone know if this simple thing exists??
    Cheers.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    I tried that on my SXi, managed to get a set of the rings off someone who had a spare set. The lower models don't have the locating holes for the studs on the rings either, so you have to cut the pins off them and stick them on. Good luck trying I stuffed mine up big time when I did them.
    Easiest way is to buy an SRi dash off ebay and use the front of that and the rear (and the circuit board) of your original dash, that way you keep all your correct mileage etc etc
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I put rings on my old LS model just glued them on , think I have a spare set simewhere but I had to glue a piece as it snapped
    Irmscher Insignia CDTI 130
    Regular Member kdadidog's Avatar
    county durham (peterlee)
    Quote Originally Posted by Ian-Highlander View Post
    managed to get a set of the rings off someone who had a spare set. Good luck trying I stuffed mine up big time when I did them.
    I thought I never seen a post with them fitted. haha.
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Lol, I couldn't remember who it was that had sent me them, forgot it was you, yeah, lol I really stuffed the dash up when I did them, I superglued the rings on and spilled some glue, tried to remove the glue and melted part of the dash front, I ended up buying an SRi dash in the end and using the front of that onto the back of my original SXi dash.
    Of course that was last year, I got my other Vec back in September which is an SRi and had them fitted as standard lol
    Apr 2009
    Stevenage, Herts
    cheers guys.
    Ian - maybe I'll do that, buy a new set of clocks and use my innards to make it up.
    Right - off to find a cheap set of clocks lol
    Regular Member coldo's Avatar
    Scotland
    Hi mate,
    I also had this issue on my 2004 LS. It was drving me nuts having the plain black dials which were uuuuuber bland at best. Even with the Blue SMD conversion I had done they still looks bad. so.....
    There are a few options here which may or may not have been covered...
    You can 1 swap the full clocks for a new set with the rings or change the dial cards accross on your existing clocks.
    Both are suprisingly easy to do and require little skill... just more time and asteady hand.
    For me, as I had the conversion done I decided to swap the dial cards across. I used the howtoguides ion here for first taking the clocks out (2 screws, a plug conector and the front dash trims off with a tug) and then the guide on how to take them appart (some clips on the clocks, some very small touque screws and the needles off). The hardest part was finding cheap dials on ebay which matched my car's current dials and spec. That took a few weeks to do.
    This is the end result I now have in my car...
    Fromt this...
    To this...
    In all it took me 30 minutes to do...
    As far as I know you can also swap the clocks from a similar modela nd they will go right in so in theory you could fit even the VXR ones into your car... Only isuess with this are you need to find clocks which match your car (petrol for petrol and Derv for Derv etc) IF you have a pre faclift you will also need ones which offer the check function on the rev counter (window with the bulb warning and door open light etc). The millage will also be off on the clocks (although will be accurate on the cim moduel).
    While I am on the suibject... as you have the LS I am assuming you have the four spoke plastic wheel? If so scoure ebay for either a signum being broken or a signum wheel which matches yours (four spoke withthe same controls for the radio etc... I have now changed my for a leather number and whata difference it makes. That one took longer to do on ebay (about 4 months of searching) but was worth the wait. Changing is a 30 minute job also and there is guides on here on how to do it.
    hope this helps.
    Colin
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    didnt metal mickey have a chrome ring?
    do you not have an issue with yours saying 160mph and new ones saying 170. surely the speedo will be out.?
    Scotland
    Not the best pick of the type of speedo I had (this pic was one I found a pic of online). The orignial went to 170 (the numbers where just writen in a different way on the dial cards) but the marks are the same.
    I have checked the speed with a road angle and a sat nav and all confirmed they are still as acurate as they were before (about 3 mph up on the true MPH).
  1. speedo chrome rings
    By mhvcbv in forum Parts for sale
    Last Post: 21st January 2010, 22:33
  2. Chrome speedo rings....
    By Steven T Davies-Moss in forum Styling
    Last Post: 23rd December 2008, 23:16
  3. Chrome rings around speedo clocks Q.2
    Last Post: 20th November 2008, 21:51
  4. Chrome rings around speedo clocks
    Last Post: 18th November 2008, 22:14
  5. matt chrome effect speedo dial rings
    By mhvcbv in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 1st October 2008, 21:30
