Results 1 to 10 of 15
Thread: Air-con mystery
    Sep 2010
    Default Air-con mystery
    As some will know, I had my air-con re-gassed in May 2010, again I had my air-con system checked over in late april this year and re-gassed. No fault was found with the system. Only 2 to 3 weeks later the gas has gone and all that happens is the air con hisses when turned on. Dropped her off today for full test and still no fault found. Re-gassed and asked to return the car in three weeks for diagnosis checking.
    Condensor checked and apparently fine.
    Anyone any ideas what might be occuring here?! - I used the system at least every day since re-gas in April so I'm stumped (as are Vauxhall!!)
    WGAF#5
    have they added a uv dye to the system ... chances are there is a pinprick hole in a pipe or a seal is leaking ... at least if they have done this you stand a better chance of finding it over a week or two as it sounds like its not leaking enough for a sniffer to find it
    Sep 2010
    yes done the dye test and had the car all day and nothing
    Aug 2010
    Leeds
    Mine was the condensor it had been leaking on the side seams.
    Take it to another dealer.
    Sep 2010
    I may take it to a specialist now it is gassed actually
    Sep 2010
    Air con gone again!! ha haaa!! EH have checked twice for leaks with their ghostbuster style vision goggles... so.... what else can they do?... and I'm NOT having a poxy corsa for a day again
    Aug 2011
    runcorn
    mine is the same i just give up and wind the windows down
    Sep 2010
    seems a common issue. Mine back for the third time now. They wouldn't listen first time when I said it had an issue only to say 'it just needed re-gassing!' ... actually 4th time
    April 2011
    June 2011
    and now August 2011
    Feb 2011
    Selby
    Try an aircon specialist - they have more experience and often different equipment that should be able to track down the leak.
    Jul 2011
    edinburgh
    Agree that this seems a common problem - Only owned my 58 1.8 vvt for 3 weeks and had to take back for a new condenser. The garage said that they have replaced hundreds of condensers on vectras and it was a known early failure item
    Thankfully mine was under warranty !
    John
  1. History Mystery
    By bigmac in forum General Chat
    Last Post: 8th June 2011, 11:50
  2. A bit of a mystery
    By watchman in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2011, 06:44
  3. Key Fob Mystery
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2010, 22:45
  4. mystery pic......
    By david.aka.judas in forum General Chat
    Last Post: 18th July 2010, 22:07
  5. A Great mystery!!
    By MLC in forum General Chat
    Last Post: 9th June 2006, 18:48
