Results 1 to 10 of 17
Thread: hid fitted
    Jul 2011
    UK
    Year : 06
    Default hid fitted
    Well took me hour and bit bulbs just didn't go in a just hope they are cliped in anyone else had this problem tryed ajusting the clip still wouldnt go
    scottish region
    No took me 5 mins all in
    Sep 2010
    Dumfries, Scotland
    Where'd you get the kit m8, and which clip you talking about? is it the one that holds the bulb in?
    When I fitted mine I used the clips with the kit as they had a slot cut out, but you may be talking about a different bit. If possible a pic would help.
    Jul 2011
    UK
    Year : 06
    Got them from hid direct car is facelift and its to hold the bulbs in the bulb just seems to pop out no matter how much force a use it won't go in to postion
    11 Post(s)
    Only pre-face require the separate clips to hold in the HID bulbs.
    Facelift should just push in and lock into position. Sounds like you need to take the headlights out and take a proper look. While you're at it, you could mount the ballasts in the dedicated slot under the headlight assembly.
    Jul 2011
    UK
    Year : 06
    Yer they just push in but don't sit right and just POP out do I do sumit to the retainer clips its because the bulbs have plasic base ain't it
    scottish region
    Slot the bulb in and clip it with the original clip that's on the headlights
    11 Post(s)
    Quote Originally Posted by marc vectra sri View Post
    Mine are plastic base, and they went in without problems. Fitted nearly 2 years ago and not moved at all.
    Have you taken the headlights out yet to have a closer look in case you damaged the locating clips while attempting an earlier fit?
    Jul 2011
    UK
    Year : 06
    No a havnt but was the same on both sides just Wont hold them in a got old hid bulb which is a h7r tho with metal base and went in no problem
    Sep 2010
    Dumfries, Scotland
    Hi m8, went out to sort my lights and took a picture for you to compair. You can see the two clip parts at the top and bottom, these are wahat hold the bulb in place. It may be that these have flattened out on yours which would explain why the bulbs pop out.
    I'd suggest lowering the bumper and taking the headlights out, only a ten minute job to be honest, then you'll be able to see what's what.
    Hope this helps.
  1. just fitted the k&n 57i .
    By nelly452 in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2011, 22:49
  2. Hid fitted
    Last Post: 29th December 2010, 19:16
  3. anyone got or fitted??
    By vectra_c_wannabe in forum Electrical & ICE (including SatNav)
    Last Post: 25th May 2010, 09:50
  4. Just Fitted.......
    By KeefyB in forum Petrol Engine related
    Last Post: 22nd January 2010, 21:38
  5. Fitted for 314mm discs but fitted with 304mm discs
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2008, 13:19
