can anyone confirm if calipers from a 2001 vectra v6 will fit an 07 sri?? and what is the disc size??
http://www.vectra-c.com/forum/showthread.php?t=139088
2001? Is that a Vec-C or B? If B, then no. If C, then they'll fit your SRi, but "SRi" in itself doesn't tell you what size brakes it has - the disks and caliper size depends on engine, not trim levels. If the SRi brakes are currently smaller then you'll need to change the caliper carriers, disks and pads and not just the caliper.
ah i see. i have the 1.9 cdti 16v 150 bhp
You have the 285mm front disks then. Assuming the GSi calipers are from a Vec-C, then they'll be the 302mm disks (they switched to 314 on the later GSi's), so you'll also need the carriers/disks/pads.
thanks for the reply's
and its hard to pick up the 302mm parts as the dealers down hear dont stock them
some dealers dont know they did a 302mm setup
as it was not on EPC when I looked it up
they may not be labelled as 302's but there will definitely be a chassis breakpoint on the listing
