Thread: cd70 navi help
    Jun 2011
    machynlleth powys
    Default cd70 navi help
    hi car went to the garage the other day and for some funny reason only the BC button out of the 4 buttons NAVI, AUDIO, BC, SOUND is working any ideas guys? i can get to the others by using the round button in the middle but its harder when your driving thanks
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    Have you done the cold reset?
    Disconnect the battery for about 1/2 hour..
    Then reconnect and see if this has cured your problem.
    Otherwise it is a facia plate off, to check the contact buttons behind it...
    but I am confident that the buttons being simple items will not be at fault.
    Aug 2011
    Hampshire
    Hi Guys,
    Have the same problem with my 07 SRi nav!! Traffic and settings buttons don't work! Very annoying when the traffic reports keep going off and you cant stop them!
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    If the cutting battery power for a few hours does not work, then the only thing I can suggest, is to remove the front facia from the head-unit... you will see that it is connected electronically via a black push fit connector... see if the connectors and pins are clean and dry.
    To get the facia off, you will need to undo all the torx screws from the side latch plates.
    Then it should be a matter of unclipping a few black plastic hook type latches..
    The facia will now simply pull off from the front of the head unit.
    Regular Member dannycturbo's Avatar
    Aug 2011
    Letchworth, Herts
    What work did you have done
  1. Cd70 navi
    By tammyman09 in forum Electrical & ICE (including SatNav)
    Last Post: 6th July 2009, 14:23
  2. Navi CD70
    By Stephen S in forum Electrical & ICE (including SatNav)
    Last Post: 1st July 2009, 20:50
  3. CD70 navi help
    By bigbeech in forum Electrical & ICE (including SatNav)
    Last Post: 31st July 2008, 10:47
