Thread: fuel pip
    Regular Member steve19cdti's Avatar
    Nov 2010
    s.wales.bridgend
    Default fuel pip
    hi notice the pip below when ignitions turns on primer pump activats to fill the filter the pip exspanse when pump stops prime it deflates do urs do it mean 120 8v cdti 54reg
    and ive got injecter (Q)
    starting problem will injector stop car starting had a reading 1,2,4,ar low and 3is high does this mean number 3 injecter gone nead replacing
    Jun 2011
    Elland
    Wouldn't have thought the pressure was so much that the pipe expands... does it expand uniformly, or baloon out in one place only? If the latter, then the pipe has a weakness in this area.
    Do a search on the '3rd injector wiring' It may be in the 'how2' section, too. 3rd injector wiring problems is well covered. IIRC if yours has the yellow connectors, then this may be an issue, but the blue connector ones have had the problem resolved (but verify this first!). There will be others on here with direct experience of 3rd injector issues and may be better able to help you.
    Nov 2010
    s.wales.bridgend
    thanks hebblemarine having pip check out the pip expands as as soon as u put ignition on it is nottisable il get video it later on and post on
    for the injector where can i get the wireing from
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by steve19cdti View Post
    You can get a kit from Vx dealers it only does one injector and comes with the wiring and 1 connector - there is a very good how to with part numbers etc - cost about £12 per kit
  1. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  2. Fuel housing sensor/fuel temp senser a
    By sri adi in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2010, 10:15
  3. high pressur fuel pump and fuel regulator ?
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 12:23
  4. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
