Results 1 to 10 of 14
Thread: Horns
    Regular Member rhodod's Avatar
    Aberdeen
    Default Horns
    My vectra C 2.0 Dti failed its mot on the horns
    neither of them work at all, ive checked the fuse and tested the horns and everything is fine
    But they refuse to work... any ideas?
    thanks
    Feb 2011
    Selby
    If the horns work when tested on a battery, and the fuse looks good, then all that is left is the wiring and switch.
    Most likely is the wiring between the switch on the steering wheel and the dashboard if it's not the switch itself.
    Aberdeen
    i took the front of the steering wheel off so i can see the metal plate that is pushed to sound the horn, gave that a push and still nothing.
    where is the switch your talking about?
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    can you link out the wires in the loom, i know on my old gold the connectors wore and then stopped working
    Aberdeen
    il have a look when i get home.
    its frustrating
    Mar 2011
    llandrindod wells
    out of interest do you get 12 v at the terminals when you press the horn, its not something stupid like a bad earth
    Aberdeen
    when you say terminals, you mean where the horns connect ( 2 pin connector)? If so, then no there is nothing coming from them at all.
    Mar 2011
    llandrindod wells
    okay gotto be the steering wheel connections then
    Aberdeen
    Could the Squib be the problem?
    Mar 2011
    llandrindod wells
    most likely
  1. Air Horns Yay or Nay??
    By redraptor_141 in forum General Chat
    Last Post: 19th July 2009, 23:16
  2. Very loud horns
    By rob 2.2dti in forum Comedy & Humour
    Last Post: 2nd September 2008, 16:04
  3. So where do I put my twin air horns........?
    By merikiito in forum Electrical & ICE (including SatNav)
    Last Post: 29th July 2008, 19:11
  4. Where are the horns?
    By hefilump in forum Electrical & ICE (including SatNav)
    Last Post: 30th August 2007, 20:45
  5. Horns !!
    By Led in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2007, 15:03
