Thread: No hot air blowing from vents
    Regular Member gibbon7000's Avatar
    lincs
    Default No hot air blowing from vents
    Driving back from work this morning, the heaters never worked. Engine temp was all as usual. Fans settings 1-4 still worked fine, just cold air pumping out
    Any idea's anyone?
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Blocked heater matrix? Heat control dial not actually working?
    I had an old Mondeo with a blocked matrix and in the middle of winter it didn't matter where the dial was pointing - it was COLD!!
    Jun 2011
    machynlleth powys
    Could be head gasket on its way out ???
    lincs
    Quote Originally Posted by si_hoss View Post
    Where abouts is the heater matrix located?
    Sep 2010
    north east uk
    Mine did this about 4 weeks ago. Turned out to be a sticking servo motor.
    Jul 2009
    manchester
    Same as mick.n mate
    lincs
    is there a way i can check this myself?
    Jul 2009
    The Rift, Cardiff
    Can you hear the motor when you turn the temp dial?
    If you take the glove box out, to the right behind the stereo you'll see the blower / air distribution unit. You should then be able to see a red (i think) arm that moves the hot/cold flap. Move the temp dial to see if there is any movement.
    lincs
    Quote Originally Posted by ChrisBilly View Post
    That'll be my first port of call then. thanks
    Oct 2007
    Shropshire
    It is summer in the uk.... Why do you want heat? Lol!
  1. Blowers not blowing hot
    By john506 in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2013, 21:04
  2. Air con blowing out warm air
    By Baggers 2.0 in forum Vectra C / Signum Troubleshooting
    Last Post: 11th August 2012, 17:26
  3. Blowing From Injectors
    By yates in forum Engine & Drivetrain
    Last Post: 15th January 2012, 00:06
  4. face lift chrome vents and rear vents
    By simon1 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2011, 21:13
  5. only blowing hot air
    By peadar in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2009, 13:19
