Thread: 3.2 V6 - common oil leak locations?
    New Member Rosencrantz's Avatar
    Dec 2010
    Australia
    Default 3.2 V6 - common oil leak locations?
    There's no doubt my 03 3.2 V6 automatic is leaking oil - the smell is unmistakeable, and plenty of bits at the bottom of the engine and nearby are covered in a film of oil (including where the exhaust passes under the engine, hence the smell).
    Thing is, I can't spot the source of it. It doesn't help that I can't get under the car properly (ie I'm limited to what I can see by crawling under - no ramps or axle stands) but none of the obvious candidates (sump plug, rear main seal) seemed to be doing it.
    Is there a common leak location higher up the engine which could be running down the side of the block and coating everything at the bottom? Where is the oil filter located? (I couldn't see it).
    It hasn't used much oil to date, but I'd prefer to nip this in the bud before I end up with a stained driveway
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    if its anything like mine it will be leaking from the rear rocker cover mate.
    aparently the rocker covers are made from plastic and over time and heat they warp slightly and allow oil to leak.
    Dec 2010
    Australia
    That would make sense - I couldn't see the rear, but the front rocker cover did seem to have a little bit of oil weeping from it (albeit nowhere near enough to be the source of this leak).
    Devon
    Another common leak is either or both of the Cranskshaft oil seals - this will show itself on the timing belt side of the engine and probably be seen running off the sump.
    The oil filter is at the front N/S of the engine just below the 02 sensors (it's a silver cansiter).
  1. earth lead locations?
    By victorM in forum Electrical & ICE (including SatNav)
    Last Post: 5th February 2012, 18:15
  2. Locations for the next meet?
    By cont1204 in forum North West (RO - Paulvectrac, ARO bonehead)
    Last Post: 9th April 2011, 20:53
  3. Leak, front end creak, refurb, bent locking wheel key and another leak =(
    By nick-v2.2 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th February 2010, 19:58
  4. VIN locations
    By awilson in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2009, 23:25
vectra c 3.2 v6 oil leaks
vectra c 3.2 v6 oil leak bottom of engine
vectra c 3.2 v6 bottom oil leak
vectra 3.2 oil leak
vauxhall signum 3.2 v6 common oil leak
vectra 3.2 oil filter sump plug
