Results 1 to 10 of 22
Thread: Spoiler & rear parking sensors fitted.
    Jun 2011
    Kent
    Default Spoiler & rear parking sensors fitted.
    I had my vandalism repairs sorted the other day.
    And at the same time had my new spoiler fitted.
    And I also got around to fitting my reverse parking sensors.
    Here is the wiring behind the bumper
    The wiring in the boot compartment (the control unit is hidden and only the sounder can be seen inside the compartment).
    Here are the sensors, fitted.
    They took about an hour to fit, the longest part was measuring up the bumper for cutting the holes for the sensors - measure 10 times and cut once so the saying goes (or something like that)
    I then ran the cables behind the bumper under the boot floor to the rubber grommet and up through the floor into the car beneath the drivers side rear light. I disconnected the multiplug for the rear lights and found the feed (white/black), stripped some insulation away and soldered the power lead live feed to that and insulated it. I ran the earth to the same earthing point Vauxhall use inside the same compartment. I tucked the control box in behind the rear boot panel & stuck the sounder to the rear panel the rear lights bolt to.
    I then cut 3 holes in the boot lining (out of sight) to let the sound filter through into the cabin more easily.
    They work perfectly and is something I have wanted to do since buying my Vec as the rear end is quite high and not so easy to see when parking.
    Regular Member Ben_'s Avatar
    Audiville, WM
    Very nice mate, is that a M3 spoiler? Seems to sit the other way to Vec lip ones.
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Quote Originally Posted by Ben_ View Post
    It Does Sit Different...Either That Or Its Upside Down
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    You not put your parking sensors in the right place.
    There are markings on the inside of the bumper for the correct positioning.
    Regular Member GTS's Avatar
    Oct 2010
    Poland
    That looks very good, althought I'd fit sensors more at the sides of rear bumper
    Sep 2010
    "spoiler upside down",.. "sensors wrongly placed".... you've made this guy feel good about his work today!!
    Regular Member MACVVT's Avatar
    May 2011
    fife,scotland
    Vehicle : vectra c
    Trim : sri
    Engine : 1.8 vvt (XE18XER)
    Mileage : 28,000
    Well yes its wrong, spoiler that is, unless you wanted it that way?
    Sep 2010
    is it the standard SRI spoiler?
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    good job man, sensors look fine to me, look well placed and well fitted with tidy wireing.
    but the spoiler does look a little wrong im afraid
    Oct 2010
    Poland
    As an non-original SRi spoiler, it's fitted correctly. We are just used to different one
  1. rear parking sensors fitted
    By cbl1985 in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2010, 19:41
  2. Just Fitted Rear Parking Sensors......at last
    By Gordon B in forum Bodywork & Interior
    Last Post: 12th September 2009, 10:31
  3. rear parking sensors fitted
    By johnnyg in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2008, 21:07
  4. rear parking sensors fitted
    By simon7257 in forum Styling
    Last Post: 16th September 2007, 19:23
  5. rear parking sensors fitted
    By j1 wyx in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2007, 17:24
