Thread: coolant question
    Regular Member Mads's Avatar
    Ipswich,.UK
    Default coolant question
    so as previously posted i done the missus water pump, cambelt etc today on her focus, when i was topping up her coolant i noticed that it said to mix with water 50/50 ratio.
    i done my cambelt etc a few months back and brought the red coolant from vx but i havent added any water as i didnt realise you had to, do you think i should drain some coolant out and add water woiuld this have harmed the engine etc
    Glasgow
    Some are ready mixed and it will tell you on the bottle. It wont harm in the short term but if it was me i would take some out and replace with water.
    Jul 2009
    The Rift, Cardiff
    The vx stuff should also be 50/50 for protection down to around -30¤c. Not too sure if undiluted can cause damage, maybe a bit too thick, damage to seals/gaskets possibly maybe. I'd drain a litre or so and refill with water, you can mix what you drain with water and keep for topping up if needed.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    VX coolant (white bottle) is good for -40°C and colder, I'd drain a bit and refill with water.
    Ipswich,.UK
    thanks guys, i will take some out and add water. think ive done about 300 miles at most so hopefully will be ok, havent noticed anything whilst driving.
    May 2008
    Tyneside
    100% solution will not do any harm, just give more protection. HTH
  1. coolant question?????????
    By kev bux in forum Engine & Drivetrain
    Last Post: 6th November 2010, 19:19
  2. coolant question!
    By blackveccyC in forum Engine & Drivetrain
    Last Post: 4th July 2010, 23:22
  3. Coolant bottle question
    By Harro in forum Engine & Drivetrain
    Last Post: 7th March 2009, 16:52
  4. dumb coolant question!
    By Adamdavi3s in forum Engine & Drivetrain
    Last Post: 23rd June 2008, 22:10
  5. Coolant Question
    By vectra 120 in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2007, 20:30
