Results 1 to 10 of 11
Thread: Spanner light very strange...
    Jul 2011
    Plymouth
    Default Spanner light very strange...
    Hi sorry but i'm from portugal and my english is not too good my car is a vectra c 53 plate 2.0dti and the car start fine i drive 15min the car start warm and spanner light comes on and the car looses power after 2 or 3 minutes the light is off but this situacion repeated very times when i driving
    I talk with a friend garage and he conect the machine and the car don't have any errors he said to me change the Maf and your problem is fixed but not I change for new one, i clean egr, i clean boost sensor, i check the vacuum pipes everything is fine and i check too turbo pipes and everything is fine the car makes black smoke if i make 4000rpm without spanner light but if the light comes on i can't cross the 3000rpm and the car makes a lot of smoke black one
    I'm worry with the car is strange and i need your help sorry i no have a lots of post about spanner lights but i don't understand because every situacion is different
    If is possible help me and sorry about my english i try learn more....
    King regards
    F@st_Esi
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi fast esi,check the vacuum hoses and the T pieces (the pipe joints)they get brittle and crack,they usually give a P0638 or P0234 code but not allways.they are the small rubber pipes around the engine,there is also a filter element in the vacuum system that gets blocked.causes loss of power and black smoking.
    YOUR ENGLISH IS BETTER THAN MY POTUGESE he he.
    Jul 2011
    Plymouth
    LOOOL thanks jonnybravo if you want i give to you some portuguese lessons( i'm kiding ok)
    I check the vacuum pipes and i think is everything ok but i saw before in the other topic how to change the vacuum pipes what do you think if i change my vacuum pipes to the new ones??? yeah if i want make top speed more power the light comes on very quickly.... you no where i can find the tube to replace for new ones??thanks
    King Regards
    F@st_Esi
    Jul 2009
    Engine : 20 Dti
    you can get the pipe at any motor spares shop,you need about 1.5 meters,remove one at a time and use old ones to cut new to size,check all t pieces for cracks when you remove them,pipe should only cost about £5,
    Jul 2011
    Plymouth
    hum ok but you no some store online to buy because i'm very new in England and i don't no where is possible buy that
    Jun 2011
    Elland
    Ebay - search for SILICONE HOSE or PIPE
    http://www.yell.com/
    search for 'car performance parts' in your area or 'car tuning' or similar.
    Try 'motor factors' as well.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Did you check ALL turbo pipes? Just recently our 2.2DTi cracked the smalles one there is i.e. the one right after the turbocharger. Have a look there too as it's often overlooked. These engines shouldn't smoke. I think you either have a boost leak (turbo pipes OR cracked intercooler) or a faulty/dirty sensor like EGR, boost sensor.
    Jul 2011
    Plymouth
    I have before two errors in a car and the mechanic deleted the error and now don't come again is aobout boost pressure something i don't no he check the tubes and he conect direct to turbo the vacuum pipes and the problem continues but i think start to change the pipes first but now the car don't start well with new MAF start 5seconds later than normal i feel the engine makes push hard to start and i think is glow plugs.....i'm very worry with the car but i don't have much time to talk with mechanic the overtimes killing me and i try DIY you think really intercooler cracked???don't tell me that but egr is cleaned i don't no really...
    Jul 2011
    Plymouth
    What the pipes size i need buy for a car....
    Jun 2011
    Elland
    Check to see if any of them are leaking first!
    You should also see what fault (spanner) codes are stored in the car. A local garage will be cheaper than the dealership for this... or if there is a member near you with a code reader that can help you...??
    Try to diagnose the fault properly, before buying bits and spending money in hope
    By Shadrack in forum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  4. Very Strange...Spanner Light
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2009, 19:17
  5. Spanner Light and strange smell!!
    By neil1194 in forum Engine & Drivetrain
    Last Post: 9th February 2008, 20:42
