Results 1 to 2 of 2
Thread: egr valve on a vectra c 2.0 dti
    Jul 2011
    gateshead
    Default egr valve on a vectra c 2.0 dti
    hi i am new to the forum and looks great, i am a new owner of a vectra 2.0 dti 03 plate and what a nightmare i have had with the diesel pump, 300 quid later thats sorted, i got the car as a non runner knew the diesel pump was gone, now i have just got the car running and its running a bit lumpy, i have put it on a tech 2 and its the egr valve, how do i clean this and go to the cheaper option, i have searched forum and found how to clean the 19 cdti ones is this the same on how to do mine? thanks in advance frankee
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi bigf and welcome,pretty straight forward remove the top engine cover,the two small coolant hoses,two bolts and the EGR valve pulls out from the manifold,you will see all the crap inside the valve,i use brake cleaner to clean but you can use carb cleaner ect,check inside the inlet manifold it will probably but bunged up with carbon if so remove manifold and clean in the same way,
  1. Will this EGR valve fit my Vectra??
    By mtqn in forum Diesel Engine related
    Last Post: 9th August 2012, 17:29
  2. Vectra dti Egr valve
    By Forest in forum Introduce yourself.
    Last Post: 15th January 2011, 17:21
  3. Vectra C EGR valve
    By Blian in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2010, 16:26
  4. Vectra C 1.8 Boost valve - Available Where?
    By CavScorpion in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2007, 09:43
  5. vectra c 2.2 DTI Blow off valve!
    By pro9 in forum Diesel Engine related
    Last Post: 5th April 2007, 00:04
Egr valve signum 2.0 dti
egr valve vectra c 2.0 dti
vectra c 2.0 dti egr valve location
egr valve vauxhall signum 20dti
change 2.0dti egr
vectra 2.0 dti egr valve bolts
where is the egr on a vauxhall vectra 2.0 dti
03 vauxhall vectra c 2.0 dti egr valve
insignia egr valve location
vectra c dti egr valve
vauxhall vectra 2.0 dti egr valve
opel vectra c 2.0 dti egr
how to delete egr valve from 2.0 dti vectra c
egr valve vauxhall vectra 2.0
04 vectra 2.0 egr valve
erc valve vauxhall vectra dti 03
egr valve vauxhall vectra 2.0 dti
