Results 1 to 10 of 11
Thread: castor and camber
    DARLINGTON
    Default castor and camber
    hello all i have had a problem with my 06 vedtra 1.9 tdi 150 the rear yyres were worn on the inside wall so much that it had got down to the ribbon on 1 tyre.had tyres from quickfit they were going to check the toe ,on the ramp 2 springs were broke on the drivers side . i have replaced all 4 springs took it back to kwick fit today they have a top of the range machine he has rectified the toe but i have a computer readout
    front left castor 4.44 deg
    camber -2.16
    front right castor 6.07
    camber in the green -0.56
    rear left toe -1.20 camber -2.10
    rear rigt toe 0.30 camber in green -1.60
    kwick fit told me that on the computer you can not adjust castor and camber drove the car for test drive pulling to the right when i let go of the wheel they gave me a full refund and said it was a mian dealer to sort out any help please living in darlingto north east
    The camber can be adjusted, they just need to know how
    The response from Kwik Fit kind of says it all
    Equally, even my local VX dealership cannot check and adjust camber, they don't have the equipment for doing this
    Find another outlet with Hunters equipment, they should be able to perform the required adjustments
    When phoning up, simply ask if they can adjust the camber settings on a Vectra C
    DARLINGTON
    many thanks for your help m8inernet
    lincolnshire
    kwitfit in scunthorpe have just bought the Hunter mutts nuts machine , £125 for full camber , castor and allignment check
    lincolnshire
    Quote Originally Posted by kevinjm View Post
    just curious mate , are your front tyres wearing ok ??
    Engine : 1.9 CDTi
    Quote Originally Posted by bembo449 View Post
    What a rip off.
    Go to www.alignmycar.com and find some garage with the same equipment. Mine cost £45 to be done.
    DARLINGTON
    front tyres ok bembo449
    DARLINGTON
    just checked your link lee gsi many thanks there is a garage in stockton 8 miles down the road ringing them in the morning to book in cheers for all of your help
    DARLINGTON
    Default castor camber update
    many thanks for all your help took my car to tyre exchange stockton to get all my allingment done waited a hour machine was freezing to it a few miles down the raod to middlesbrough 25 mins alter all done with the hunter machine and the put 70kg on both front seats KWICK FIT DID NOT he had to adjust front toe £45 for it to be done but for the messing about £30 well happy would recomend tyre exchane and hunter machine as i said many thanks to this forum for all your help STEERING ME IN THE RIGHT DIRECTION (what a pun)
    lincolnshire
    so you can feel the difference ??
  1. Camber? Camber Kits??
    By RyanNI in forum Handling & Braking
    Last Post: 13th December 2010, 11:11
  2. camber kit
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2009, 09:23
  3. Castor camber settings
    By goonturbo in forum Suspension, Wheels & Brakes
    Last Post: 6th March 2009, 01:16
  4. camber
    By linley85 in forum Handling & Braking
    Last Post: 30th November 2008, 15:05
  5. Camber
    By Daywalker in forum Handling & Braking
    Last Post: 22nd June 2008, 10:46
