Results 1 to 3 of 3
Thread: Xtrons 714 Steering Control Wiring
    Nov 2010
    Plymouth
    Default Xtrons 714 Steering Control Wiring
    Im just in the process of fitting my Xtrons 714 to my half canbus 2002 veccy. All is going well apart from I cannot locate the cables coming from the steering wheel (6 Buttons) to the connector that used to connect to the CDR2005 unit.
    Wanted to get everything working before fitting it in the cage and fitting fascia etc.
    Any help greatly appreciated.
    Nov 2010
    Plymouth
    Talking
    All Sorted now!
    Pin 2 on block A of the ISO connector (the one with +12V, GND etc) is the steering wheel control pin.
    A few things to note though......
    Ignore the instructions that come with the TD714 regarding the "Bleep". If you set a multimeter to bleep on continuity when a button is pressed on the wheel it does not bleep! The resistance is not low enough.
    Also, wire the GND pin of the connector to a good, stable ground. Otherwise, when you setup the steering wheel controls on the TD714, you will find the voltages measured are ambiguous and ultimately, the steering controls will not work properly.
    Dont be tempted to use the ISO connector ground.
    Remember, this info is only relevant to a Pre-facelift, Half CANBUS (6 Button steering wheel) car.
    Happy Wiring!
    Feb 2011
    London
    Can you explain in detail what you did to wire up the steering controls??
  1. Halfcan & fullcan Steering Wheels & Audio control wiring
    By Woody in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2013, 11:54
  2. Stalk Control Wiring loom, Where Do I plug it in! See pics
    By chriso123 in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2012, 14:09
  3. Steering wheel wiring
    By Nez in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2012, 22:27
  4. Steering wheel control wiring
    By the-converter in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2011, 12:37
  5. Traction control wiring
    By bobbyboy in forum Handling & Braking
    Last Post: 17th January 2006, 14:36
