Thread: Ignition live near center speaker.
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Default Ignition live near center speaker.
    Hi all just got back from my weekend break and meeting up with a member from another forum to collect my Road Angel 2.
    now i want to hard wire it in as nothing worse than a springy cable running down my dash now ive got it situated right at the bottom in the middle of my windscreen just above where the center speaker is. what im needing to know before i go hammer and tongs at it, is there somewhere to splice the power cable in there somewhere or is it easy enough to run a cable down the back to the ciggy socket so i can wire it in under there? i just plan on cutting off the socket and useing the cable provided to save cash soany insight would be great, Cheers
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    If you take the front vents out and the centre speaker out, you can see a small gap goes all the way through. I fitted my satnav aerial this way, mounted the aerial above the centre speaker and ran the cable through to the back of the head unit. You can run a cable through and tap off the ignition live on the radio or down to the cigarette lighter, easy job
    Nov 2010
    BRECHIN
    cheers ian, when you say front vents do you mean ones around the screen?
    Nov 2010
    BRECHIN
    right, found the hole lol, now just looking at my lighter socket i have a wire taped to it with a female spade on it. is this one ok to use? or is it something different? cheers
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Yup, pop the silver dash strip out above the glove box and you'll see the four torx screws that hold the centre vents and screen in place, undo them and it just pops out.
    Edit: too late you're there lol
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Quote Originally Posted by TimTay View Post
    As long as it's off the black wire (positive) and not the brown one (earth).
    Nov 2010
    BRECHIN
    cheers Ian, jobs a gudden
  1. Wiring an amp, need an ignition live and permanent live in the boot
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 16:36
  2. center dash speaker
    By jpbroad1970 in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2012, 12:00
  3. Parrot Mki9100 & Center speaker
    By iani in forum Electrical & ICE (including SatNav)
    Last Post: 5th May 2011, 20:13
  4. disconnect center speaker
    By bartsisgod in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2010, 19:41
  5. center speaker suprise
    By Ben999 in forum Electrical & ICE (including SatNav)
    Last Post: 18th March 2009, 23:09
