Thread: Swirl Bar Tap Washer Mod
    New Member Dave Greaves's Avatar
    Mar 2011
    Bolton
    Default Swirl Bar Tap Washer Mod
    B&Q have changed their supplier of these washers. Does anyone know where these can be obtained from. Also I have about 4m/m of crud on the top of the manifold. Am I correct in thinking that the valves are leaking and is worth proceeding ?
    TIA
    Dave
    Regular Member Bartekuk's Avatar
    Jul 2011
    Weymouth
    try ebay
    Mar 2011
    Bolton
    Tried that but the inside diameter isn't listed by any of the sellers, its important that it's 3m/m, not sure if thats the standard. I will quiz a plumber tomorrow.
    Regular Member coooky's Avatar
    May 2011
    washington
    b&q still sell them mate i got mine from there the other week
    just look on the packets for size 9/16" x 5/32" x 3/32"
    May 2011
    washington
    P&p a bit steep for a packet of washers
    http://www.ebay.co.uk/itm/NEW-ORACST...item35aed8f2d2
    May 2011
    washington
    also forgot to say i done the mod as the bar was off but my performance was ok put the bar back on and the car went into limp mode took the bar off and its running fine
    Mar 2011
    Bolton
    Thats a strange one, might be something else for me to look forward to ! Thanks for the replies.
    Regular Member Danger_MouseUK's Avatar
    Jan 2010
    Merseyside
    How does one put the bar on, any tips or techniques, i can't get my hands anywhere near in deep enough to put them back on?
    Jun 2011
    manchester uk
    Default put on
    I used a piece of solid copper wire through the hole in the bar to lower it into the area then after lining up each flap used the handle end of a screwdriver to tap it into place gently before removing the wire from the hole. ps i used the upturned numberplate cap fix not the washer one and it seems to be ok (500 miles now since fix)
    Simon
    May 2011
    washington
    i used a piece of wire bent to craddle the bar and then guided with a large screwdriver and push it in place was a right job getting it on took around 20 mins
  1. swirl bar off
    By vectraross in forum Engine & Drivetrain
    Last Post: 20th August 2012, 12:12
  2. swirl bar fix
    By littlegreenmartian in forum Engine & Drivetrain
    Last Post: 23rd May 2012, 20:15
  3. Swirl x
    By dannyp in forum Detailing and Car Care Discussion
    Last Post: 22nd August 2011, 17:59
  4. swirl or not to swirl
    By lesron in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2011, 19:53
  5. swirl bar
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 24th December 2009, 17:49
