Results 1 to 10 of 24
Thread: 1.9cdti 150 what to check?
    Regular Member bigdave1701's Avatar
    York
    Default 1.9cdti 150 what to check?
    I know there are hundreds of threads on here about things to check for when buying a car but I can't seem to find any of them!?! Can anyone pop up a link to one such thread as I want to be armed with all possible knowledge before I pick up my new car.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Check swirl flaps (inlet manifold) - Take engine vanity cover off and look down behind the fuel rail, you will say the rod. If it's in place and there is no sign of oil the manifold is fine. Otherwise it is on the road out or done for if the rod is off.
    EGR valve - Take it for a test drive; if there is a hesitation at 2,000rpm or a flat spot under 2,000rpm, then the valve is jammed open or jamming open.
    Vacuum hoses - They give the same symptoms as a faulty EGR valve. They are located to the front right of the engine near the battery/grille. Splits in these are common. Cheap fix though.
    Injector wiring - If all plugs are Blue then the engine already has the updated plugs. If Yellow they will probably need changed.
    Thermostat - If the engine takes a long time to heat up or doesn't heat up at all; the thermostat is probably jammed open.
    York
    That perfect!! Thank you very much.
    Full Member Big Sig's Avatar
    Not forgetting the Dual mass flywheel. Although thats on every model, not just the 1.9.
    York
    Goosed DMF = metallic grinding when lifting clutch?...
    York
    Just to check, is the injector wiring a recall or just a possible fault?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by bigdave1701 View Post
    More of a rattle.
    It's not a recall - though it should be. I covered under Vx warranty if you have one. The cost to have all replaced is about £120ish.
    York
    What's the actual issue with the yellow plugged injector wiring? is it a lack of power supply? I worry that if I fing theyre the yellow ones, my only argument is that theyre the wrong colour but i don't know why that matters.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    The plug deteriorates with heat, and causes the engine to shut down.
    York
    test driving the car at 6.15pm so will report back on the above.
  1. Poor performance from 1.9cdti....Check your boost pipes
    By richardn in forum Engine & Drivetrain
    Last Post: 31st October 2016, 22:19
  2. another 1.9cdti 150 juddering.... quick check as seen stickys
    By skip85 in forum Engine & Drivetrain
    Last Post: 20th July 2012, 21:58
  3. Wheels refurbed, Check - Car Buffed and Polished, Check! !
    By messermitch in forum Quick Photo Album
    Last Post: 18th July 2012, 23:18
  4. 1.9cdti 150 health check
    By mann3210 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2012, 07:33
  5. 1.9cdti 134000 miles - what to check to improve perfomance
    By cheekylemon in forum Vectra C / Signum Car Chat
    Last Post: 19th October 2008, 13:58
